Autohide of the ibar/help makes desktop Icons flicker
When the autohide function of the ibar in E24 is selected. When autohide activates, the objects like the icons ,desk apps flicker as if something is being dragged across the desktop instead of smooth movement. Its irritating and i think its the reason the grapics get jumbled up or freezes. How can i remove the jittery effect?
If you change the setting of the compositor from "software" to "opengl" (or vice-versa) and back again if wanted, this "jittering" will stop.
Maybe a log-out and logging in again will do the same. :thinking:
