BTRFS file system and SSD
#1
#2
@Thanatermesis see in bold in case it is important
" Is Btrfs optimized for SSD?
https://btrfs.wiki.kernel.org/index.php/FAQ#Is_Btrfs_optimized_for_SSD.3F
There are some optimizations for SSD drives, and you can enable them by mounting with -o ssd. As of 2.6.31-rc1, this mount option will be enabled if Btrfs is able to detect non-rotating storage.
Note that before 4.14 the ssd mount option has a negative impact on usability and lifetime of modern SSDs which have a FTL (Flash Translation Layer). See [the ssd section in Gotchas](Gotchas - btrfs Wiki)for more information.
Note that -o ssd will not enable TRIM/discard. "
#3
it is and the features for SSD are included in elive, but in the actual newer versions all the filesystems supports ssd well, including reiser4
well, these should not support it: reiser3, xfs, ext3, ext2, jfs... but they are not included unless you really want them to be added
check my answer here :slight_smile: SSD maintenance in Elive - maybe we need to put this on a FAQ page? ala "does elive support ssd?" (and showing this list)
yeah, elive kernel is newer and seems like btrfs works better
