~/cache/efreet not updating on E23
shot-2020-02-23_04-15-50
Recently changed my Internal Harddisk from a 250 GB to 1 TB toshiba ( spinning disk rather than SSD) and get this error message on Startup to E23. It does not stop my the functioning of the laptop but there seems to be a momentary lapse when the whole screen is frozen except for the pointer. Is this because of the size of the HDD. Is this something to worry about?
If you simply copied your Elive data to the new disk I would suggest to reinstall Elive (migration mode will take care of everything)
Otherwise, just try to delete your ~/.e dir to be re-created
