Changing zsh themes (3.8.9)
Hi there,
I hope I'm posting this in the right location. I've given the beta version of Elive a spin and so far I like it a lot. I'd like to report an issue I encountered while trying to switch zsh prompts (see screenshot).eliveZshPrompt
I'm not sure what causes this, but it seems to be one of those little hiccups that you'd want to have tackled during the beta phase.
Kind regards and keep up the good work :).
Welcome to the forum @nevel ! :slight_smile: yeah seems like there's a problem with some prompt themes, by other side the only tested / well-featured / suggested is the default one, which is a modification of the sorin theme from prezto zsh. Maybe an updated zsh prezto code will fix the code (which has been forked from the official one on github for elive use, but not updated since long time), you can see the elive modifications on here: Commits · Elive/prezto · GitHub
I happen to like prezto, and haven't ran into this issue before. I'll check if a "rebase" helps.
