E27 container Module like CairoDock
Hello everyone.
I’ve added a "containers" module for E27. Since I use E16 and am also switching to E27, I was missing the containers feature—which is really handy for grouping applications together. I came up with the concept and sketched out the operational diagram, then enlisted Claude’s help to build it, as I don't have the technical skills to do the project on my own. I haven't uploaded the project to GitHub yet. Could you test it to see if the module's code is correct and if it's suitable for sharing? I’ve uploaded it to FreeTransfer (available for 30 days). Have a great day.
I'll give it a go to see how it works ..... I'm taking it's a separate shelf that sets up categories that you choose to create.
I'm surprised 'Claude" got this far ..... :innocent:
It's quite a lot of code/settings to go through especially since I'm not knowledgeable enough to see if it's all needed or not. I suspect the real go/no-go will come down to rasterman and I have no idea what his stance on AI coding is (I love how the French, like everything, turn it around into IA. :rofl2: ).
Alas I run into a "make" error, which I suspect is down to me having 'enlightenment-pro' installed, not 'enlightenment'.
I can try using the standard enlightenment but methinks you (or Claude) need to build-in the fact that Elive also has an own version.
triantares ~/e-containers-0.8.2 ❯❯❯ make
cc -O2 -fPIC -Wall -Wno-format-truncation -DEFL_BETA_API_SUPPORT -DEFL_EO_API_SUPPORT $(pkg-config --cflags enlightenment elementary) -shared -o module.so e_mod_main.c $(pkg-config --libs enlightenment elementary)
Package enlightenment was not found in the pkg-config search path.
Perhaps you should add the directory containing `enlightenment.pc'
to the PKG_CONFIG_PATH environment variable
Package 'enlightenment', required by 'virtual:world', not found
Package 'elementary', required by 'virtual:world', not found
e_mod_main.c:6:10: fatal error: e.h: No such file or directory
   6 | #include "e.h"
compilation terminated.
make: *** [Makefile:9: module.so] Error 1
Never mind .... I oversaw that enlightenment-dev was needed. :shocked:
It installs fine once that is done.
It runs as you describe and I've still got to get my head around a few things to be sure if I personally find it useful.
There is certainly a thingy to see to: Internationalization i.e building-in that the installed module uses the language that is set as default on the target ..... now it's French only.
On top it should also adhere to the icon-theme settings on the target and preferably have it's own icon.
This icon mix is messy:
Not quite sure I understand the purpose. Is this supposed to be just a way of keeping a group of apps together and launchable? In that case, I put desktop launchers in a separate directory then have a simple script that launches a yad window with the contents of the directory. I have my own version of "Elive Center" that does that (but apparently without the overlaid [?] helpful text of the second yad window), and looks like this:
The yad script just points to the /usr/share/elive-center/links directory and shows the desktop icons that are linked to in there. Pretty simple. With the current window dimensions, two more apps could be added to the links directory, so it's a "container" in my mind. I apologize if I mis-read the intent of the OP.
I didn't know there was a difference; I'll give Pro a try.
To be taken into account: internationalization—meaning the installed module must use the target system's default language (currently, only French is available).
Furthermore, it should respect the target system's graphical settings and, ideally, have its own icon.I am going to correct the internationalization of the language.
I'm going to fix the internationalization and ensure it follows the system's graphical settings.
I'm not sure I fully understand the objective. Is it simply a matter of grouping applications together and being able to launch them?
Yes, for E27, it's about adding containers to the dock.
It's meant for E27 (not E16) and can be used in a separate shelf or embedded i.e in a taskbar. It will show it's contents on mouse-over, contrary to 'yad' that will require a mouse click and open a widget that will require closing again.
Hello everyone.
@triantares:
  • Added 50 languages ​​(/home/tux/.e/e/modules/econtainers/locale/).
  • Econtainers follows the target system's theme.
  • Added an E-Containers icon (/home/tux/.e/e/modules/econtainers/e-container.png).
I’ve tested it, and it works on my Elive Trixie system. I haven't tested it on enlightenment-pro. I switch between the two by running enlightenment-dev or enlightenment-pro in the terminal—is that right?
E-Containers 0.9.4:
No, not really. Enlightenment-pro is the extra package for patreon supporters that removes a lot of the debugging stuff that is in standard E ..... making it faster and lighter than current vanilla E27.
It's either the one or the other (installment of .deb).
It ultimately doesn't make a difference. I just hadn't noticed that I didn't have 'enlightenment-dev' on this machine. Installing that pulled in the right elementary too. :innocent:
That was my bad, I hadn't read the README and just did a brainless 'make'. :shocked:
I'll try upgrading, this time adhering to the README.
In your case, I'd publish on github (I prefer gitlab, it's not M$ owned) as a private-project and use invites to allow others to see and download it. The Elive group there allows public and private projects.
If you want to I can add you to the Elive group on gitlab but you'll need to register an account on gitlab first.
OK, upgraded by the book and language is set right as is the icon.
I don't think it's a good idea to use a file-manager icon for e-containers.
Do you mind if I, in time try to cobble something up (for beauty-line) or do you prefer to do it yourself?
I'm happy to let you handle it; I'm far from having your skills.
Cobbled up a quicky. Happy to redesign or change if you wish.
I wont add it to elive-beauty-icons yet until the module is really 'finished' and made public (or not), so you need to add it to the package itself for now.
With pleasure.
I'll leave it to you to post and share it once you've improved it.
If you're happy I'll leave it as is and we can always edit or change when the e-containers are deemed acceptable for publication. :innocent:
