If you want to experiment with the ZRAM feature, I have this script:
#!/bin/bash
# zram-config.sh - Init-system-agnostic ZRAM (compressed RAM swap) manager
# Detects and integrates with: systemd, OpenRC, runit, sysvinit.
# Falls back to direct /sys configuration with a warning if none detected.
# Usage:
# zram-config.sh enable [--percent N] [--algo zstd|lz4|lz4hc] [--force]
# zram-config.sh disable
# zram-config.sh set-percent N
# zram-config.sh status
# Auto-detection:
# - PERCENT from RAM: <=2GB -> 100% <=4GB -> 75% <=8GB -> 50% >8GB -> 25%
# - ALGO: zstd > lz4hc > lz4 (whichever the kernel supports)
# Persistence is written per-init-system (unit/script + enable).
# Runtime uses direct /sys/block/zram0 manipulation so it works everywhere.
set -euo pipefail
SCRIPT_PATH="$(readlink -f "$0" 2>/dev/null || echo "$0")"
CONF_DIR=/etc/zram-config
CONF_FILE=$CONF_DIR/config
SYSCTL_DROPIN=/etc/sysctl.d/99zz-zram-priority.conf
SYSCTL_REVERT=/etc/sysctl.d/99-zram-reverted.conf
BACKUP_DIR="/var/backups/zram-config-$(date +%F)"
INIT=""
info() { echo ">>> $*"; }
warn() { echo "WARN: $*" >&2; }
die() { echo "ERROR: $*" >&2; exit 1; }
require_root() { [[ $EUID -eq 0 ]] || die "must be run as root"; }
detect_init() {
if [[ -d /run/systemd/system ]] && command -v systemctl >/dev/null; then
echo systemd
elif command -v rc-service >/dev/null && [[ -d /etc/runlevels ]]; then
echo openrc
elif command -v sv >/dev/null && { [[ -d /etc/sv ]] || [[ -d /etc/service ]] || [[ -d /var/service ]]; }; then
echo runit
elif command -v update-rc.d >/dev/null && [[ -d /etc/init.d ]]; then
echo sysvinit
else
echo none
fi
detect_percent() {
local mem_mb
mem_mb=$(awk '/^MemTotal:/{print int($2/1024)}' /proc/meminfo)
if (( mem_mb <= 2048 )); then echo 100
elif (( mem_mb <= 4096 )); then echo 75
elif (( mem_mb <= 8192 )); then echo 50
else echo 25
fi
detect_algo() {
if modprobe -n zstd 2>/dev/null || modinfo zstd >/dev/null 2>&1; then echo zstd
elif modprobe -n lz4hc 2>/dev/null; then echo lz4hc
else echo lz4
fi
validate_percent() {
local p="$1"
[[ "$p" =~ ^[0-9]+$ ]] || die "percent must be an integer"
(( p >= 10 && p <= 200 )) || die "percent out of range (10-200)"
read_conf() {
local key="$1"
awk -F= -v k="$key" '$1==k{print $2}' "$CONF_FILE" 2>/dev/null | head -1
# Runtime (init-agnostic): direct /sys/block/zram0 manipulation
runtime_enable() {
local percent="$1" algo="$2"
local mem_bytes size_bytes
modprobe zram 2>/dev/null || modprobe zram num_devices=1 2>/dev/null || true
local i
for i in 1 2 3 4 5; do
[[ -b /dev/zram0 ]] && break
sleep 0.2
done
[[ -b /dev/zram0 ]] || die "zram module failed to load (/dev/zram0 missing)"
swapoff /dev/zram0 2>/dev/null || true
echo 1 > /sys/block/zram0/reset 2>/dev/null || true
if ! echo "$algo" > /sys/block/zram0/comp_algorithm 2>/dev/null; then
warn "algorithm '$algo' not available in kernel, falling back to lz4"
echo lz4 > /sys/block/zram0/comp_algorithm || die "cannot set comp_algorithm"
fi
mem_bytes=$(awk '/^MemTotal:/{print $2*1024}' /proc/meminfo)
size_bytes=$(( mem_bytes * percent / 100 ))
echo "$size_bytes" > /sys/block/zram0/disksize
mkswap /dev/zram0 >/dev/null
swapon -p 100 /dev/zram0
info "zram0 active: ${size_bytes} bytes (${percent}% of RAM), algo=$algo, priority=100"
runtime_disable() {
modprobe -r zram 2>/dev/null || true
info "zram0 stopped and module unloaded (if idle)"
# Persistence: write per-init-system unit/script
persist_systemd() {
cat > /etc/systemd/system/zramswap.service <<EOF
[Unit]
Description=ZRAM compressed swap (managed by zram-config.sh)
After=multi-user.target
Before=swap.target
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=$SCRIPT_PATH _boot
ExecStop=$SCRIPT_PATH _stop
[Install]
WantedBy=multi-user.target
EOF
systemctl daemon-reload
persist_openrc() {
cat > /etc/init.d/zramswap <<EOF
#!/sbin/openrc-run
description="ZRAM compressed swap (managed by zram-config.sh)"
depend() {
after localmount
before swap
start() {
ebegin "Starting ZRAM compressed swap"
$SCRIPT_PATH _boot
eend \$?
stop() {
ebegin "Stopping ZRAM compressed swap"
$SCRIPT_PATH _stop
eend \$?
EOF
chmod +x /etc/init.d/zramswap
persist_runit() {
mkdir -p /etc/sv/zramswap
cat > /etc/sv/zramswap/run <<EOF
#!/bin/sh
exec 2>&1
$SCRIPT_PATH _boot
exec sleep infinity
EOF
chmod +x /etc/sv/zramswap/run
cat > /etc/sv/zramswap/finish <<EOF
#!/bin/sh
$SCRIPT_PATH _stop
EOF
chmod +x /etc/sv/zramswap/finish
# Hook into the active runsvdir (Debian: /etc/service, Void: /var/service)
if [[ -d /etc/service ]]; then
ln -sfn /etc/sv/zramswap /etc/service/zramswap
elif [[ -d /var/service ]]; then
ln -sfn /etc/sv/zramswap /var/service/zramswap
elif [[ -d /etc/runit/runsvdir/default ]]; then
ln -sfn /etc/sv/zramswap /etc/runit/runsvdir/default/zramswap
fi
persist_sysvinit() {
#!/bin/sh
### BEGIN INIT INFO
# Provides: zramswap
# Required-Start: \$local_fs
# Required-Stop: \$local_fs
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: ZRAM compressed swap (managed by zram-config.sh)
### END INIT INFO
case "\$1" in
start) $SCRIPT_PATH _boot ;;
stop) $SCRIPT_PATH _stop ;;
restart) $SCRIPT_PATH _stop; $SCRIPT_PATH _boot ;;
status) swapon --show | grep -q zram0 ;;
*) echo "Usage: \$0 {start|stop|restart|status}"; exit 1 ;;
esac
EOF
persist_init() {
case "$INIT" in
systemd) persist_systemd ;;
openrc) persist_openrc ;;
runit) persist_runit ;;
sysvinit) persist_sysvinit ;;
none) warn "no init system detected; zram will be started now but NOT persist across reboots" ;;
esac
# Service control (per init system)
svc_enable() {
case "$INIT" in
systemd) systemctl enable zramswap.service >/dev/null 2>&1; systemctl start zramswap.service ;;
openrc) rc-update add zramswap default >/dev/null 2>&1; rc-service zramswap start ;;
runit) sv start zramswap 2>/dev/null || sv start /etc/sv/zramswap 2>/dev/null || "$SCRIPT_PATH" _boot ;;
sysvinit) update-rc.d zramswap defaults >/dev/null 2>&1; /etc/init.d/zramswap start ;;
none) "$SCRIPT_PATH" _boot ;;
esac
svc_disable() {
case "$INIT" in
systemd) systemctl disable --now zramswap.service 2>/dev/null || true; rm -f /etc/systemd/system/zramswap.service; systemctl daemon-reload ;;
openrc) rc-service zramswap stop 2>/dev/null || true; rc-update del zramswap default 2>/dev/null || true; rm -f /etc/init.d/zramswap ;;
runit) sv down zramswap 2>/dev/null || sv down /etc/sv/zramswap 2>/dev/null || true; rm -f /etc/service/zramswap /var/service/zramswap /etc/runit/runsvdir/default/zramswap 2>/dev/null; rm -rf /etc/sv/zramswap ;;
sysvinit) /etc/init.d/zramswap stop 2>/dev/null || true; update-rc.d -f zramswap remove 2>/dev/null || true; rm -f /etc/init.d/zramswap ;;
none) "$SCRIPT_PATH" _stop ;;
esac
svc_restart() {
case "$INIT" in
systemd) systemctl restart zramswap.service ;;
openrc) rc-service zramswap restart ;;
runit) sv restart zramswap 2>/dev/null || { "$SCRIPT_PATH" _stop; "$SCRIPT_PATH" _boot; } ;;
sysvinit) /etc/init.d/zramswap restart ;;
none) "$SCRIPT_PATH" _stop; "$SCRIPT_PATH" _boot ;;
esac
# Config + sysctl
write_config() {
mkdir -p "$CONF_DIR"
cat > "$CONF_FILE" <<EOF
# Managed by zram-config.sh on $(date +%F)
PERCENT=$percent
ALGO=$algo
PRIORITY=100
EOF
write_sysctl() {
cat > "$SYSCTL_DROPIN" <<'EOF'
# zram tuning: prefer compressing cold pages to zram (priority 100 beats disk swap)
vm.swappiness = 100
vm.page-cluster = 0
EOF
rm -f "$SYSCTL_REVERT"
sysctl --system >/dev/null 2>&1 || true
revert_sysctl() {
rm -f "$SYSCTL_DROPIN"
cat > "$SYSCTL_REVERT" <<'EOF'
vm.swappiness = 60
EOF
backup_existing() {
mkdir -p "$BACKUP_DIR"
local f
for f in "$CONF_FILE" "$SYSCTL_DROPIN" /etc/systemd/system/zramswap.service \
/etc/init.d/zramswap /etc/sv/zramswap "$SYSCTL_REVERT"; do
[[ -e "$f" ]] && cp -a "$f" "$BACKUP_DIR/" 2>/dev/null || true
done
[[ -d /etc/sv/zramswap ]] && cp -a /etc/sv/zramswap "$BACKUP_DIR/" 2>/dev/null || true
info "Backups (if any) in $BACKUP_DIR"
# Commands
cmd_enable() {
local percent="" algo="" force=0
while (( $# )); do
case "$1" in
--percent) percent="${2:-}"; shift 2 ;;
--algo) algo="${2:-}"; shift 2 ;;
--force) force=1; shift ;;
*) die "unknown option: $1" ;;
esac
done
require_root
backup_existing
percent="${percent:-$(detect_percent)}"
algo="${algo:-$(detect_algo)}"
validate_percent "$percent"
if [[ -f "$CONF_FILE" ]] && (( ! force )); then
local cur_p cur_a
cur_p=$(read_conf PERCENT); cur_a=$(read_conf ALGO)
if [[ "$cur_p" == "$percent" && "$cur_a" == "$algo" ]]; then
info "already configured (PERCENT=$percent ALGO=$algo); use --force to reapply"
fi
fi
info "init system detected: $INIT"
info "applying runtime: PERCENT=$percent ALGO=$algo"
runtime_enable "$percent" "$algo"
write_config "$percent" "$algo"
write_sysctl
persist_init
svc_enable
info "--- status after enable ---"
cmd_status
cmd_disable() {
require_root
backup_existing
info "disabling zram (init: $INIT)"
svc_disable
runtime_disable
rm -f "$CONF_FILE"
rmdir "$CONF_DIR" 2>/dev/null || true
revert_sysctl
info "--- status after disable ---"
swapon --show || true
free -m
cmd_set_percent() {
local percent="${1:-}"
[[ -n "$percent" ]] || die "usage: $0 set-percent N"
require_root
[[ -f "$CONF_FILE" ]] || die "$CONF_FILE not found, run 'enable' first"
info "updating PERCENT=$percent (init: $INIT)"
sed -i "s/^PERCENT=.*/PERCENT=$percent/" "$CONF_FILE"
grep -q '^ALGO=' "$CONF_FILE" || echo "ALGO=$(detect_algo)" >> "$CONF_FILE"
grep -q '^PRIORITY=' "$CONF_FILE" || echo "PRIORITY=100" >> "$CONF_FILE"
svc_restart
sleep 1
cmd_status
cmd_status() {
echo "=== init system: $INIT ==="
echo "=== $CONF_FILE ==="
cat "$CONF_FILE" 2>/dev/null || echo "(not present)"
echo
echo "=== sysctl ==="
sysctl vm.swappiness vm.page-cluster 2>/dev/null || true
echo
echo "=== persistence ($INIT) ==="
case "$INIT" in
systemd) systemctl is-enabled zramswap.service 2>/dev/null || echo "(not enabled)" ;;
openrc) rc-update show 2>/dev/null | grep zramswap || echo "(not enabled)" ;;
runit) ls -la /etc/service/zramswap /var/service/zramswap 2>/dev/null || echo "(not linked)" ;;
sysvinit) ls /etc/rc*.d/ 2>/dev/null | grep -i zramswap || echo "(not enabled)" ;;
none) echo "(no init system)" ;;
esac
echo
echo "=== zramctl ==="
zramctl --output-all 2>/dev/null || echo "(not available)"
echo
echo "=== swapon ==="
echo
echo "=== free -m ==="
free -m
# Internal: called by the init script/unit
cmd_boot() {
local percent algo
percent=$(read_conf PERCENT)
algo=$(read_conf ALGO)
[[ -z "$percent" ]] && { warn "no config in $CONF_FILE"; exit 1; }
runtime_enable "$percent" "${algo:-lz4}"
cmd_stop() {
runtime_disable
main() {
INIT=$(detect_init)
local cmd="${1:-}"
if [[ -z "$cmd" ]]; then
echo "Usage: $0 {enable [--percent N] [--algo zstd|lz4|lz4hc] [--force] | disable | set-percent N | status}"
exit 1
fi
shift || true
case "$cmd" in
enable) cmd_enable "$@" ;;
disable) cmd_disable ;;
set-percent) cmd_set_percent "$@" ;;
status) cmd_status ;;
_boot) cmd_boot ;;
_stop) cmd_stop ;;
*) echo "Unknown command: $cmd"; exit 1 ;;
esac
main "$@"
The script is init-agnostic, works with openrc or systemd, runit and sysvinit
Run it as root with the argument "enable" to activate it or "disable" if you want to stop using it, use "status" to see the actual status
Depending of our experiencies using it, it may be a good thing to include by default on Elive ![]()
