Error running apug
W: Failed to fetch http://repo.wheezy.deb-security.elivecd.org/debian-security/dists/wheezy/updates/main/binary-i386/Packages 301 Moved Permanently
W: Failed to fetch http://repo.wheezy.deb-multimedia.elivecd.org/dists/wheezy/main/binary-i386/Packages 301 Moved Permanently
W: Failed to fetch http://repo.wheezy.deb-security.elivecd.org/debian-security/dists/wheezy/updates/contrib/binary-i386/Packages 301 Moved Permanently
W: Failed to fetch http://repo.wheezy.deb-multimedia.elivecd.org/dists/wheezy/non-free/binary-i386/Packages 301 Moved Permanently
W: Failed to fetch http://repo.wheezy.deb-security.elivecd.org/debian-security/dists/wheezy/updates/non-free/binary-i386/Packages 301 Moved Permanently
W: Failed to fetch http://repo.wheezy.debian.elivecd.org/debian/dists/wheezy/main/binary-i386/Packages 301 Moved Permanently
W: Failed to fetch http://repo.wheezy.debian.elivecd.org/debian/dists/wheezy/contrib/binary-i386/Packages 301 Moved Permanently
W: Failed to fetch http://repo.wheezy.debian.elivecd.org/debian/dists/wheezy/non-free/binary-i386/Packages 301 Moved Permanently
W: Failed to fetch http://repo.wheezy.debian.elivecd.org/debian/dists/wheezy-backports/main/binary-i386/Packages 301 Moved Permanently
W: Failed to fetch http://repo.wheezy.debian.elivecd.org/debian/dists/wheezy-backports/contrib/binary-i386/Packages 301 Moved Permanently
W: Failed to fetch http://repo.wheezy.debian.elivecd.org/debian/dists/wheezy-backports/non-free/binary-i386/Packages 301 Moved Permanently
I see the same errors/warnings. Looks like the repo’s are gone.
Good afternoon :-). The same thing happens with my PC. I have not been able to install some applications.
Elive seems to me an excellent GNU / Linux distribution. Congratulations to your developer
Thanks all for reporting this (important) issue :slight_smile: , it is actually reported and tracked here:
http://bugs.elivecd.org/index.php?do=details&task_id=727
It should be fixed soon in these next days
Isn’t it just an “End Of Life” issue for wheezy? Maybe we should be mirroring those repo’s while we still can?
I don’t mind adding a 1 or 2Tb disk to my home-server to that end, if need be.
Nope, not end-of-life by wheezy :slight_smile: check this explanation, specially the “lenny” part :eyepopping: :
Thanks for the proposal of mirroring! we actually are doing it thanks to Gary, but it may be possible that we need it in the future! :slight_smile:
This should be perfectly fixed now, comment here if you see issues in the future :slight_smile:
7 posts were split to a new topic: "apug" command disappeared
