Periodic loss of mouse wheel scrolling ability
As already mentioned by @Durhammer in the "bugs and "annoyances" thread.
I can confirm that this happens intermittently on my E27 (Trixie, systemd) desktop.
Just a short, simple loss of scrolling capability after a window switch or such ..... I'm not able pinpoint exactly when it exactly happens but often when i.e switching or closing a tab in the browser.
I've also seen this temporary loss in 'thunar', albeit seldom.
To be clear, I don't have a physical mouse but use my touchpad with 2 fingers to scroll.
Yes. I have this too mostly if i use whatsapp or telegram and then go back to brave or vivaldi. In this case you can scroll with a pressed middlewheel or you can minimize the browser and maximize it again and you can scroll normally.
Oh and I am in E16 (bookworm) not in E27 (Trixie) so this may be an older issue.
I'm suspecting a kernel or firmware driver. :thinking:
Now that I know more people have seen this, I'll start keeping a beady eye as when this actually happens and what logs, if any, I can find at that moment.
It would be great if you could keep notes too ..... maybe we can pinpoint where/when this is actually happening, by comparing notes.
I've been trying to figure out how to get the scroll wheel action back just for my sanity. It happened again just a little while ago in my Vivaldi browser whilst mucking around (and up, likely) in the forum. Nothing I could do changed it until I minimized the browser window and brought up my other browser window (for the upper monitor). The scroll wheel was working fine again, and when I returned to this browser window, it was also back in action.
FWIW, here's my trackball info (Device-1):
~ >>> inxi -Bx
Battery:
ID-1: BAT1 charge: 37.1 Wh (87.9%) condition: 42.2/48.8 Wh (86.4%)
volts: 12.1 min: 11.1 model: SAMSUNG Electronics status: not charging
Device-1: hidpp_battery_0 model: Logitech ERGO M575 Trackball charge: 75%
status: discharging
@earl31515 -- since we appear to be the only ones having similar issues, maybe we should share our system info in case that has anything to do with it. I'm going to paste my "inxi -Fxxx" command output below, could you do the same?
System:
Host: elive1 Kernel: 6.1.0-47-amd64 arch: x86_64 bits: 64 compiler: gcc
v: 12.2.0 clocksource: tsc
Desktop: Enlightenment v: "1.0.31" tk: EFL v: N/A wm: e16 with: tint2
vt: 7 dm: LightDM v: 1.26.0 Distro: Debian GNU/Linux 13 (trixie)
Machine:
Type: Laptop System: SAMSUNG product: RF511/RF411/RF711 v: 10HX
serial: Chassis: type: 9 serial:
Mobo: SAMSUNG model: RF511/RF411/RF711 v: 10HX
serial: uuid:
BIOS: American Megatrends v: 10HX.M034.20110426.SSH date: 04/26/2011
Battery:
volts: 12.1 min: 11.1 model: SAMSUNG Electronics type: Li-ion serial: N/A
serial: 07-03-70-37 charge: 75% rechargeable: yes status: discharging
CPU:
Info: quad core model: Intel Core i7-2630QM bits: 64 type: MT MCP
smt: enabled arch: Sandy Bridge rev: 7 cache: L1: 256 KiB L2: 1024 KiB
L3: 6 MiB
Speed (MHz): avg: 800 min/max: 800/2900 cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 31926
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Samsung Co driver: i915 v: kernel arch: Gen-6 ports:
active: LVDS-1,VGA-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:0116 class-ID: 0300
Device-2: Silicon Motion WebCam SCB-1100N driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-1.1:3 chip-ID: 2232:1008
class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.7 driver: X: loaded: modesetting
unloaded: fbdev,vesa dri: crocus gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1600x2820 s-dpi: 96 s-size: 422x744mm (16.61x29.29")
s-diag: 855mm (33.68")
Monitor-1: LVDS-1 pos: primary,bottom-l model: ChiMei InnoLux 0x1733 res:
mode: 1600x900 hz: 60 scale: 100% (1) dpi: 106 size: 382x215mm (15.04x8.46")
diag: 448mm (17.6") modes: 1600x900
Monitor-2: VGA-1 pos: top-right model: Dell P2214H serial: KW14V53L0TWL
res: mode: 1920x1080 hz: 60 scale: 177% (0.5625) to: 1080x1920 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") modes: max: 1920x1080
min: 720x400
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 1 drv: swrast
gbm: drv: crocus surfaceless: drv: swrast x11: drv: crocus
inactive: wayland,device-0
API: OpenGL v: 3.3 vendor: intel mesa v: 25.0.7-2~bpo12+1 glx-v: 1.4
es-v: 3.0 direct-render: yes renderer: Mesa Intel HD Graphics 3000 (SNB GT2)
device-ID: 8086:0116
Info: Tools: api: eglinfo,glxinfo x11: xdriinfo, xdpyinfo, xprop, xrandr
Audio:
Device-1: Intel 6 Series/C200 Series Family High Definition Audio
vendor: Samsung Co 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: Intel USB2.0 Device driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 bus-ID: 2-1:2 chip-ID: 8087:1024
class-ID: 0300 serial: 20170726905955
Device-3: AKAI MPKmini2 driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 bus-ID: 2-2.2:5 chip-ID: 2011:0715
class-ID: 0103 serial: 0001
API: ALSA v: k6.1.0-47-amd64 status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
Network:
Device-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter vendor: Askey
driver: wl v: kernel pcie: speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 14e4:4727 class-ID: 0280
IF: wlp2s0 state: up mac: b4:74:9f:7c:bd:95
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Samsung Co driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: b000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: down mac: e8:11:32:44:7e:5f
Bluetooth:
Device-1: Broadcom BCM2070 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 3-1.3:3 chip-ID: 0a5c:219c class-ID: fe01
serial: B4749F622E6F
Report: hciconfig ID: hci0 rfk-id: 3 state: down bt-service: stopped
rfk-block: hardware: no software: no address: B4:74:9F:62:2E:6F
Drives:
Local Storage: total: 1.14 TiB used: 140.12 GiB (12.0%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
speed: 6.0 Gb/s tech: SSD serial: S3Z8NB0M368074J fw-rev: 2B6Q scheme: MBR
ID-2: /dev/sdb vendor: SK Hynix model: SC311 SATA 256GB size: 238.47 GiB
type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 tech: SSD
serial: MJ7BN46881090BA23 fw-rev: 0204 scheme: GPT
Partition:
ID-1: / size: 118.19 GiB used: 22.37 GiB (18.9%) fs: ext4 dev: /dev/sda10
Swap:
ID-1: swap-1 type: partition size: 12 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda9
Sensors:
Src: /sys System Temperatures: cpu: 57.0 C mobo: N/A
Fan Speeds (rpm): N/A
Info:
Memory: total: 8 GiB available: 7.67 GiB used: 3.52 GiB (45.9%)
Processes: 206 Power: uptime: 2h 51m states: freeze,standby,mem,disk
suspend: deep wakeups: 0 hibernate: platform Init: SysVinit v: 3.14
rc: OpenRC v: 0.45.2 runlevel: default default: 2
Packages: 2611 pm: dpkg pkgs: 2601 pm: flatpak pkgs: 10 Compilers:
gcc: 12.2.0 Shell: Zsh v: 5.9 running-in: xterm inxi: 3.3.38
I'm testing something in relation to this mouse issue and would like to hear what your experiences are.
I noticed that we are using browsers that by default do not use the system window titlebar but use their own bar.
So I enabled the native systembar(s) on my machine on firefox, vivaldi, chromium and thunderbird.
It looks like that stopped the mouse issue and ..... visibility of the browser in the pager is a lot better.
Thus:
Anyone willing to test this too, for a while at least?
Interesting observation. Does that mean that E might place non-complying windows in a fixed location -- say, like the top left of the virtual screen space? If so, that might explain why initially, two of my favorite apps -- Simplenote (great markdown note system that works across many OSes) and Xfe file manager (possibly the lightest file manager there is, albeit with throwback looks to W95 or XP) -- opened in that space and couldn't be moved until I learned about the Ctrl+F7 thing. Now, I suppose after having been "remembered", they behave nicely.
Okay, so is that just a matter of turning on the GTK or native theming in Vivaldi?
CERTAINLY! If something as seemingly not relevant to mouse wheel scrolling can be caused by not using E's window bars, it makes me wonder what other insidious effects E might have on other aspects of the affected apps. For example, I've noticed that one of the sites I visit daily in Vivaldi seems to have a memory leak, such that my conky reports 100% memory usage until I close that tab. So if it also fixes that, great, but it will leave a sour taste for E in my mouth to have that forced upon me.
EDIT: okay, I had seen that it was supposed to be enabling "GTK" but found the "native" thing in the Vivaldi settings and enabled it and restarted Vivaldi. Operators are standing by....
It has more the looks of it that E has difficulty in ascertaining the exact info or presence of those windows, the absence of the browser in the pager does suggest that. . That, however is a layman's guess and I suspect that E-devs will say it isn't possible and require further proof, hence me looking for confirmations. :innocent:
I don't know if this will help, but here it is:
System:
Host: Elive-Spaceship Kernel: 6.11.10+bpo-amd64 arch: x86_64 bits: 64
compiler: gcc v: 12.2.0 clocksource: tsc
Desktop: Enlightenment v: "1.0.31" tk: EFL v: N/A with: cairo-dock vt: 7
dm: LightDM v: 1.26.0 Distro: Elive GNU/Linux 12 (bookworm)
base: Debian 12.15
Machine:
Type: Desktop System: Alienware product: Alienware Aurora R12 v: 1.1.30
serial: Chassis: type: 3 serial:
Mobo: Alienware model: 07W25T v: A00 serial:
part-nu: 0A63 uuid: UEFI: Alienware v: 1.1.30
date: 03/12/2025
CPU:
Info: 8-core model: 11th Gen Intel Core i7-11700F bits: 64 type: MT MCP
smt: enabled arch: Rocket Lake rev: 1 cache: L1: 640 KiB L2: 4 MiB
L3: 16 MiB
Speed (MHz): avg: 800 min/max: 800/4800:4900 cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800 bogomips: 79872
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: NVIDIA GA106 [GeForce RTX 3060] vendor: Dell driver: nvidia
v: 535.261.03 arch: Ampere pcie: speed: 2.5 GT/s lanes: 8 bus-ID: 02:00.0
chip-ID: 10de:2503 class-ID: 0300
Device-2: Lenovo 500 RGB Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 1-4.3:6 chip-ID: 17ef:482f class-ID: 0e02
serial: 01.00.00
Display: x11 server: X.Org v: 1.21.1.7 driver: X: loaded: nvidia
gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: DP-0 pos: left res: mode: 1920x1080 hz: 144 scale: 100% (1)
dpi: 82 size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: HDMI-0 pos: primary,right res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 93 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.261.03 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings x11: xdriinfo,
Audio:
Device-1: Intel vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:f1c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 8
bus-ID: 02:00.1 chip-ID: 10de:228e class-ID: 0403
API: ALSA v: k6.11.10+bpo-amd64 status: kernel-api
Network:
Device-1: Realtek Killer E3000 2.5GbE vendor: Dell driver: r8169 v: kernel
pcie: speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:3000
class-ID: 0200
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: 30:d0:42:ea:26:3e
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel pcie: speed: 2.5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 168c:0042 class-ID: 0280
IF: wlp4s0 state: down mac: cc:6b:1e:42:3a:c5
Bluetooth:
Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 1-14:10 chip-ID: 0cf3:e009 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: CC:6B:1E:42:3A:C6
bt-v: 5.0 lmp-v: 9 sub-v: 25a hci-v: 9 class-ID: 6c0104
RAID:
Hardware-1: Intel Comet Lake PCH-H RAID driver: ahci v: 3.0 port: 5020
bus-ID: 00:17.0 chip-ID: 8086:06d6 rev: class-ID: 0104
Drives:
Local Storage: total: 4.8 TiB used: 2.01 TiB (42.0%)
ID-1: /dev/sda vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: ZFL489MC fw-rev: 1003
scheme: GPT
ID-2: /dev/sdb vendor: Toshiba model: HDWD130 size: 2.73 TiB
speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: Z8P4MH2AS fw-rev: ACF0
scheme: GPT
ID-3: /dev/sdc vendor: Crucial model: CT275MX300SSD4 size: 256.17 GiB
speed: 6.0 Gb/s tech: SSD serial: 18021A6C8C3C fw-rev: R060 scheme: GPT
Partition:
ID-1: / size: 250.8 GiB used: 34.26 GiB (13.7%) fs: ext4 dev: /dev/sdc2
ID-2: /boot/efi size: 299.4 MiB used: 620 KiB (0.2%) fs: vfat
dev: /dev/sdc1
Swap:
Alert: No swap data was found.
Sensors:
Src: /sys System Temperatures: cpu: 60.0 C pch: 46.0 C mobo: N/A gpu: nvidia
temp: 42 C
Fan Speeds (rpm): cpu: 5324 mobo: 1067 gpu: nvidia fan: 30%
Info:
Memory: total: 64 GiB note: est. available: 62.49 GiB used: 9.25 GiB (14.8%)
Processes: 318 Power: uptime: 0m states: freeze,mem,disk suspend: deep
wakeups: 0 hibernate: platform Init: systemd v: 254 target: graphical (5)
default: graphical
Packages: 2718 pm: dpkg pkgs: 2702 pm: flatpak pkgs: 16 Compilers:
gcc: 12.2.0 Shell: Zsh v: 5.9 running-in: x-terminal-emul inxi: 3.3.38
Time will tell, but so far, no scroll wheel issues. Again, time will tell.
But still have the memory (leak?) issue with Vivaldi, on one site mainly. I need to check what versions of Vivaldi I use on other distros (sorry to say, but don't have this memory problem on those) compared with this'n (Version 8.2.4133.84 (Official Build) (x86_64), Chromium Version 152.0.7977.160). I'll be back....
That's not a thing from elive. Also in Windows Vivaldi gets slower and slower. That's the reason why i moved to brave.
But I still use Vivaldi for Youtube. Because you can youse different VPN wtihin the browsers. So my Vivaldi is in Macau where i can watch youtube without ads and my brave is in another location to browse normally. (I use Proton VPN)
So do I and I'm happy as a lark with 'librefox' on Elive and 'duckduckgo' on my JollaPhone. :innocent:
@triantares -- again, so far, so good with the mouse wheel scrolling loss issue after switching to the native window for Vivaldi. Yet still, Vivaldi on Elive uses way more memory than on my other distros running Debian or Devuan. I checked my MX 25 distro and its Vivaldi browser. Initially, with way over twice the number of tabs open, memory usage was in the 30-40% range. Here's what the browser version and system info looked like (also did a browser upgrade):
Version
8.2.4133.68 (Official Build) (x86_64)
Chromium Version
152.0.7977.137
Memory problem doesn't exist
Installing new version
Version
8.2.4133.87 (Official Build) (x86_64)
Chromium Version
152.0.7977.169
Memory problem doesn't exist. well over 2X tabs
$ inxi -S
System:
Host: mx-RF711 Kernel: 6.12.107+deb13-amd64 arch: x86_64 bits: 64
Desktop: Openbox v: 3.6.1 Distro: MX-25.3_x64 Infinity Nov 9 2025
I also brought up Peppermint OS and Vivaldi:
Version
7.9.3970.60 (Official Build) (64-bit)
Chromium Version
146.0.7680.218
No problem with memory & well over 2X the tabs
But will be upgrading to 8.2.4133.87
~$ inxi -S
System:
Host: Samsung-rf711 Kernel: 6.19.14-2-liquorix-amd64 arch: x86_64 bits: 64
Desktop: Openbox v: 3.6.1 Distro: PeppermintOS daedalus
So multiple different versions of the browser did not have the problem on other distros. Upgraded both to the latest, 8.2.4133.87, and still had no problem.
Since my Elive Vivaldi version was not up-to-date, I just installed the latest here as well. The good news is that with the same problem web sites, my memory usage has not (yet) gone over 80%. I guess that's a big win over 100%, but the bad news is that it's still waaay more than the other setups.
Oooh -- also that is after disabling four extensions I have installed, which I did not do on the other distros (so they might use even less memory!). Let's see what happens when I re-enable the extensions. Yep, as expected, memory usages is up to 85%. Good that it's not at 100%, though!
I'll also go back and test the other distros with the extension disabled for grins.
Very strange.
Aaaarrrggghhh. Sure, it does seem to have fixed the "mouse issue" but now I cannot do things like grabbing the window title bar to move it. I can only use the extremely kludgy Alt+F7 thing, the up/down/left/right arrows and then Esc to get out of it. Elive giveth and Elive taketh away!
Let's keep things on topic here .... meaning related to the mouse issues and create a separate thread for the alleged memory usage. :offtopic:
That's weird, I have exactly the opposite on E27.
On E16 with my 3840x2160 on an 11" monitor, the title bar is extremely small but the bar underneath can also be grabbed to move.
The bar is even too small to show the title fonts fully. This really looks bad. :grimacing:
This is a theme by @Thanatermesis so I'll wait out his reaction.
The E27 bar is a lot cleaner.
You can also move a window with ctrl+alt+left mouse -> hold and move the window.
GREAT TIP, @earl31515 -- thanks!
Ah, @triantares -- it turns out that the teeny title bar was somewhat hidden in the border between the two monitors. I gingerly moved the mouse (trackball) pointer to just barely into the upper monitor view and could grab the bar and move the window. But I'll be using Earl's tip from now on. Way easier than trying to find the t-bar.
And yes, I was thinking I needed to open a separate post on the browser RAM issue. Thanks for doing that!
I'm also getting really close to saying the scrolling thing is fixed.
So am I. I've already gone as far as to mentioning it at Enlightenment and hope someone can do something with the info.
I do think the native title-bar on E16 needs to be relatively bigger. I mean for a touch-screen that teeny size is an absolute No-Go.
