So I use discord and veracrypt. In E16 they used to be in a little systray in the upper-left corner of the screen.
I launched Discord just now, and...I can't find the systray.
I don't even know if Discord launched at startup; I doubt it.
How can I make it so that Discord launches automagically at login and where is the systray?
UPDATE:: I found both
For launching at boot: in main menu, go to Settings. All. Apps. Startup applications.
For the systray: right click on shelf, choose "Shelf" and then "Contents", add "systray", and reboot. It only seems to have the icon when e24 autostarts it, but I might be wrong. (EDIT 3: No, simplescreenrecorder is in the systray just fine when e24 doesnt autostart it, and the icon actually works )
Slight issue tho: Discord is just being a warning icon, like so:
So How do I make it so that its the actual discord icon, and that when I have unread messages it puts a little red dot beside the icon?
Ok so it seems like it now works for some stupid reason. Maybe it was still loading (for a few hours), I dunno.
Heres what it looks like:
EDIT: Seems like discord shows the warning icon all the time EXCEPT when i have unread messages aka the red dot is there. So I guess its an issue with the image file. Ill try another reboot later.
EDIT 2: Actually, the icon works when it's been there for about an hour, but then I get a message, back to warning symbol, even after I read the message, still at warning symbol. So I suppose it's an issue with loading the icon. I'll try a reboot later but I'm testing lrzip
with an 86.9GB monero blockchain
just looking at the threads that i still need to read found this one...
should the title be changed? the category? maybe the entire thread is not needed anymore?
still have the discord systray issue
