Task icons in Tint2 taskbar
I have been away from Elive for a while with a new distro (Artix) on which I crafted a nice Tint2 dock/panel. I'm trying to make a similar one work for Elive 3.8.52 and am running into some snags and would appreciate some input!
A bit of background -- having been around for a while :rofl: early on I got rather used to the Windows menus and stuff focused in the left and bottom, so most of my tint2 panels have been vertical ones with the start menu at the bottom and the exit button at the top. When I started using Elive, I grew to like the Cairo-dock setup, but not its size, lack of detail customization, and apparent interference with typing* (when music tracks switch). As for the size, it generally stays around 75 MB (+/- 10 MB) on my system.
Tint2 dock/panels like mine are usually less than 10 MB. Since I also put my custom conky on the left side, having tint2 at the bottom keeps it from getting in the way of the conky (even though with the tint2 panel in auto-hide mode, it really shouldn't matter!).
So far, all I have is a collection of launchers (trying to not use buttons) and a taskbar. I'm using the BeautyLine set of icons everywhere in Elive and they're really nice. The problem I'm having right now is that the apps launched and showing in the taskbar are using their "vendor" icons. There's a few that are using the BeautyLine icons (nemo, mousepad, audacious), but not Vivaldi browser and Xterm. How can I get these two (and any others that might get launched) to use their BeautyLine equivalent?
I tried setting the BeautyLine theme (?) globally using the "Customize look and feel" app (which seems to be lxappearance app), but it didn't work for the above two items on the taskbar.
Here's a screenshot of the tint2 dock work-in-progress:
Elive_Screenshot_2026-10-08_13:17:45__815x79
Launchers on the left side of the separator look good with assigned BeautyLine icons. Nemo, mousepad, and audacious are okay in the taskbar on the right, but not the browser and terminal. And hahaha -- the Elive Center icon in the taskbar is cool except for the facts in another forum post I just entered (Elive Center window empty and can't be closed). The thing on the right is likely the screenshot task icon.
So other than modifying every @#$% desktop file in the system, how do I get this fixed?
Thanks in advance! Elive is cool!
*This issue seems only to be with Cairo-dock, and it is SOOOO annoying. I'll be typing something (like in here) and a little player pop-up overlay will show up and whatever I typed while it's showing is lost. I have a tint2 executor that I'll incorporate into my dock that can start/pause/stop audacious and control the volume with the mouse/trackball wheel and not get in the way.
Still dunno how to get the icons set globally, but at least my tint2 volume/player control executor is working great!
Elive_Screenshot_2026-10-09_11:41:30__694x71
I failed to point out at the outset that the app icons in the Cairo-dock taskbar have the nice BeautyLine icons. So is the problem that tint2 doesn't have a feature for decorating the taskbar but Cairo-dock does? I had been led to believe it should be a global GTK theming issue.
Sigh. Finally investigated via internet search to discover that yes, Cairo-dock indeed itself has machinations in its taskbar plugin to do the icon theming. Also went back to my original tint2 dock design on Artix, which is running in Openbox and thus has some system-wide theming, and could see the same vanilla app icons in the taskbar. Uncle!
About the icons changing when running ...... I see something similar.
The added launchers use the stock Elive icons although tint2.conf itself shows beauty-line. :open_mouth:
The running apps do adhere to the set theme.
I suspect tint2 uses the icon that is set in the .desktop file of the app in "/usr/share/applications/" and those point to the vanilla elive icon or their own.
On my the machine here I use extra self-made .desktop files, so you might consider doing something similar for existing files.
Lastly, just for skeets and giggles (and maybe others who have never dabbled with tint2) .... I have an old video about configuring tint2 through the UI.
I removed the 'solution' icon there, as it doesn't show a solution to the title of the thread but merely that you found the icon-setting in cairo-dock (which admittely is well hidden) :rofl2:
Thanks, @triantares !
Yes, I'm aware that I COULD manually edit the icons in the system desktop files, but all of them? No. I suppose there could be a mass edit to point to BeautyLine versions, but I'm not sure they all have the same icon names in BeautyLine. I know they oughta, but maybe not. And that would be a huge kludge that you'd have to do all over again if you changed the system icon theme. Supposedly XDG looks in $XDG_DATA_HOME, which by default is ~/.local/share/icons so I put a link to the system's BeautyLine icons folder in there, and it did no good. It might be that XDG only uses 48x48 .png icons. BeautyLine only has scalable .svg files, so I'd have to use Imagemagick or similar to do a mass conversion of all of them. At least I'd only need the apps!
And yes, I've also used the interactive tint2 configuration GUI. It's nice, but after the initial setup, I wind up manually editing the tint2rc file. I haven't learned to do a lot of fine control via the GUI.
As a side note, Trixie doesn't seem to have the latest tint2. It only has version 17.0.1 . I had wondered why it kept barking about my "execp_name" setting that I had used when I developed my volume control/player control executor on Artix, which has tint2 17.0.2 . The execp_name setting is used when you do something in a separate script that is not the main (volume control) script, so that it refreshes the execp script to show the volume (this is for the mute, etc. control script). Somehow, this must have been required in 17.0.2, because it's not really an issue in 17.0.1 without the execp_name and the tint2_refresh (?) command associated with it.
I appreciate you UN-solving the post, but I have to say that making the feature available would be quite an undertaking. It would have to be agnostic of taskbar versions (e16/e27/tint2/plank/etc.). I haven't tried plank again, but maybe I should. I do know that the same taskbar icons issue is on my other distros that use Openbox. I can't remember if it's the same on the ones running JWM (Q4OS) or IceWM (my pitiful little HP Stream netbook). I'll have to check.
No, not all of them. Just copy the ones you want to a folder and point tint2 to it. Like I showed in the 2nd image.
They do but not all apps are present there or even have .desktop file.
I'm a bit confused by what you're saying (not sure I understood what your picture was showing, either).
Initially, I put my tint2 launcher desktop files with the modified icon setting into ~/.local/share/applications and that was fine, but (1) then both the Elive desktop main menu and my generated jgmenu had the app twice in the menus, and (2) it did nothing for the app icon that showed up in the taskbar.
I moved the launcher app desktop files to a new folder under ~/.config/tint2 and pointed the tint2 launcher directives to them and got rid of the first issue above, but not the second.
In researching this, I've seen numerous similar complaints in other distros and DE's, such as Cinnamon, KDE, Openbox, etc. I have yet to see a global solution, only manually editing the system desktop file.
For tint2 you can create/use any folder you wish and point tint2 to it in the space the red arrow is pointing to in image 2. That way other apps wont find them.
Not sure what that translates to in the resulting tint2rc. Can you show that?
Don't be chicken just try it yourself .... it can't harm anything. :rooster:
Maybe not HARM, Harm! (See what I did there?) But NOOOOOO -- not what I'm asking for!
Elive_Screenshot_2026-10-12_12:58:31__1387x66
Then don't ask .... just find out if it's a tint2 glitch or not.
I abandoned tint2 (and plank and cairo dock) for a reason ... this was one of them.
I quite like Cairo-Dock
Yeah, but it blocked too much of my screen, especially with animated icons enabled.
Tint2 didn't do that nor does the E27 ibar.
I believe there is a small flaw with the E27 iBar. The one at the bottom works fine, but the one I created on the left—which appears when I hover over it with the mouse—sometimes makes it difficult to grab a window (in full-screen mode) and resize it using the mouse. Every now and then, I have to force the left-hand iBar to reappear just so I can grab the window's edges and resize it. I love E27!
If you've got autohide enabled a fullscreen window will cover it, even if the shelf is set to be on top. Resizing full-screen windows is always impossible, though.
The same goes for full-screen video, which is a nice feature.
I haven't looked if there's a setting somewhere else that explicitly configures full-screen windows. You might want to do some poking around. :innocent:
Found it:
I knew it would be somewhere. :slightly_smiling_face:
Thank you !!!!!
