Hi,
is it possible to activate the touchscreen in elive?
Hi,
if only my x86 tablet wasn’t locked, i’d try and tell you immediately
i’m curious about it too
From the elive 3.0 preview looks like it does work with touch
Yes it just works out of the box, unless the drivers are not supported correctly by Elive (which uses an old kernel)
Dell XPS 13 touch working well
can even hit the small x in the corner to close window as good as any distro
