Not yet tested for nvidia parts, but two little things for now:
-In the enlightenment menu > settings > session: there was tree lignes & check boxes, now four, in two + two rows, and the ones at right side did not fit in the window limits, so are a bit crunched...
-in Cairo, the battery indicator is changed and time to go turns unreadable...
EDIT: btw, still softs that didn't launch from Cairo, e.g. Discs...
More to go!
p.s.: is it me or the download rating start is at a better level than lasts?
I still test with other machines, but it's in live mode, and e.g. with a M4400 it's the same...
I made the test with full battery & plugged; So I think that it's not relative to somewhat hardware, but a wrong "screen economy" routine into startup sequence..?
It was at least partially resolved in a past beta, so..???
