I've installed Elive 3.0.6 (x86) on an old computer.
While installing Elive and after using it, I noticed it seemingly have no support for btrfs. Assuing this is because of old kernel (3. something) ?
My question is : Are file system support tied to the kernel version, or is it something that could possible be added afterwards, regardless of the kernel age ?
Yes, they are.....and as 3.0.6 is so outdated that there's not much chance of getting more modern stuff to run.
If that were possible we'd have already done it.
Your best bet would be to try and install the Beta 3.8.20 version on that machine.
I may try the beta, but I have now something that works (simple file server and ssh) and it's one of very few distros that are able to run on that old computer. So unless the 3.0.6 is soon to get no support (security wise) then I think I'm stick to it.
The computer are not able to boot on USB so every time I test a different distro I have to spend a little more than one DVD (sometimes burner process fails).
Exactly what are the specs of that old machine?
And what usage do you have in mind for it?
Stable is agood choice for old machines and still works quite well with a few age restrictions, whereas Beta is fairly lightweight by itself too but might make a machine struggle when it comes to RAM usage.
There's not very much that can be done to make Stable better or more "modern" than it already is .... in general it's usefull "as is" or it just isn't enough for a lot of people, depending on what they want to use it for..
