A few points regarding Elive, AppImages, and "Trixie."
Hello,
I had Elive 3.8.50, which was upgraded to "Trixie" (Debian Testing) automatically during an update.
I have been testing the use of AppImages.
Everything seemed to be working quite well.
I decided to try Elive 3.8.52 and performed an upgrade.
"Trixie" is now gone, and some AppImages that previously worked (such as displaycal.appimage) no longer function.
It appears the issue is that "GLIBC_2.38" cannot be found; however, in Elive (based on Debian 12), only GLIBC_2.36 is available.
The problem is that I no longer know how to upgrade to "Trixie" within Elive—it doesn't happen automatically.
I tried upgrading Debian via the terminal, but Elive stopped functioning correctly.
I have since performed a fresh, complete installation of Elive 3.8.50.
How can I upgrade to "Trixie"?
Should I install Elive 3.8.52 first?
How should I go about this?
I am not a programmer; I test photography software on Debian (Elive) and Fedora. My primary focus is ensuring that AppImages work correctly, which helps avoid the dependency conflicts I encountered with Arch in the past.
Debian is interesting because Elive still includes X11, and some software requires X11 to function.
Furthermore, Enlightenment is a very compelling and highly configurable interface.
For someone using it for photography, the only thing missing is the ability to set an ICC display profile during startup.
It seems that xcalib is the tool to use, but there is no simple way to implement it.
Thank you.
That does NOT happen automatically, it needs to be invoked specifically.
The point being that you "downgraded" Trixie to Bookworm by installing 3.8.52
Upgrading to Trixie on Elive is still in the test phase, albeit reasonably bug-free ATM.
Absolutely, after which do an upgrade using 'apug' in the terminal.
Once done: elive-upgrader --betatest in that same terminal and cross your fingers.
We will be expecting bug reports, should you encounter any mishaps. It is beta-testing after all :innocent:
Hello, I use quite a few AppImages on Elive Trixie (all my emulators, except RetroArch), and everything works—no issues at all.
Hello,
for example Displaycal 3.9.19 appimage don't start
If possible, start from a terminal ... that way it's easier to ascertain where the "fault" lies.
Just saying "not starting", ultimately says nothing at all, like: "my printer doesn't print". :face_with_head_bandage:
