I can't edit application menu using Settings>All>Menus>Menu Settings.
I don't know if i want to add a new category for newly installed applications how to do that.....
I never tried but after seeing your post, I just looked everywhere and didn't find anything to achieve that.
When @Thanatermesis is back, he'll be able to let you know if it can be done.
It is so fast for me to Alt + Esc to access App (typing the 1st letters of the app name) that I don't need such a feature.
And as Elive is not memory hungry, I leave all the apps I often use opened in different workspace to access it easily using the Virtual Desktop(workspace) applet/gadget at the top right.
Category? what you mean?... it should be automatically-correctly shown in their specific categories, otherwise the problem should be by the application itself which didn't provided a correctly structured .desktop file (on which also is set which category/ies to use)
I don't know .desktop file structured well or not. I've installed Clementine Music Player which should automatically shown up in the Sound section. Unfortunately i didn't find it there. If any application fails to detect its specific category it should fall into a category named Others if it possible. If it doesn't is there any way to make it manually?
This is how exactly works ![]()
Nope, it should contain a correct .desktop file for it to be displayed correctly
How you installed clementine? from the elive default repos? try to run the command: api clementine
