Can not install anything on fresh install
cannot install with apt-get install or use apt-get update as it just hangs trying to contact servers, i can ping the servers though ...
fresh install of latest elive
Sometimes the repositories do not react when they're being worked on or updated.
Try again later.
BTW,
Elive has shortcuts for different 'apt' commands where i.e 'apug' is a combined update and upgrade command, 'api' is install and 'apui' is update and install.
See the output of:
"alias |grep apt"
It's been 2 days... how much longer?
Hit http://repo.wheezy.elive.elivecd.org wheezy/games i386 Packages
Hit http://repo.wheezy.elive.elivecd.org wheezy/ports i386 Packages
Hit http://repo.wheezy.elive.elivecd.org wheezy/fixes i386 Packages
Hit http://repo.wheezy.elive.elivecd.org wheezy/drivers i386 Packages
Hit http://repo.wheezy.elive.elivecd.org wheezy/multimedia i386 Packages
Hit http://repo.wheezy.elive.elivecd.org wheezy/non-free i386 Packages
Ign http://repo.wheezy.elive.elivecd.org wheezy/drivers Translation-en_GB
Ign http://repo.wheezy.elive.elivecd.org wheezy/efl Translation-en_GB
Ign http://repo.wheezy.elive.elivecd.org wheezy/elive Translation-en_GB
Ign http://repo.wheezy.elive.elivecd.org wheezy/fixes Translation-en_GB
Ign http://repo.wheezy.elive.elivecd.org wheezy/games Translation-en_GB
Ign http://repo.wheezy.elive.elivecd.org wheezy/main Translation-en_GB
Ign http://repo.wheezy.elive.elivecd.org wheezy/multimedia Translation-en_GB
Ign http://repo.wheezy.elive.elivecd.org wheezy/non-free Translation-en_GB
Ign http://repo.wheezy.elive.elivecd.org wheezy/ports Translation-en_GB
Err http://repo.wheezy.deb-security.elivecd.org wheezy/updates Release.gpg
  Could not connect to repo.wheezy.deb-security.elivecd.org:80 (212.48.93.106), connection timed out
Err http://repo.wheezy.deb-multimedia.elivecd.org wheezy Release.gpg
  Could not connect to repo.wheezy.deb-multimedia.elivecd.org:80 (212.48.93.106), connection timed out
Err http://repo.wheezy.debian.elivecd.org wheezy Release.gpg
  Could not connect to repo.wheezy.debian.elivecd.org:80 (212.48.93.106), connection timed out
Err http://repo.wheezy.debian.elivecd.org wheezy-backports Release.gpg
  Unable to connect to repo.wheezy.debian.elivecd.org:http:
Reading package lists... Done
W: Failed to fetch http://repo.wheezy.debian.elivecd.org/debian/dists/wheezy/Release.gpg  Could not connect to repo.wheezy.debian.elivecd.org:80 (212.48.93.106), connection timed out
W: Failed to fetch http://repo.wheezy.deb-security.elivecd.org/debian-security/dists/wheezy/updates/Release.gpg  Could not connect to repo.wheezy.deb-security.elivecd.org:80 (212.48.93.106), connection timed out
W: Failed to fetch http://repo.wheezy.debian.elivecd.org/debian/dists/wheezy-backports/Release.gpg  Unable to connect to repo.wheezy.debian.elivecd.org:http:
W: Failed to fetch http://repo.wheezy.deb-multimedia.elivecd.org/dists/wheezy/Release.gpg  Could not connect to repo.wheezy.deb-multimedia.elivecd.org:80 (212.48.93.106), connection timed out
W: Some index files failed to download. They have been ignored, or old ones used instead.
Well, you yourself stated:
But alas, that is NOT the latest Elive. It's the old -Stable which is based on Debian Wheezy and isn't supported any more. It's there as a demo of how a finished Elive used to be.
I'm surprised you're able to ping those ..... I certainly cannot.
The current latest Elive version is 3.8.40 (Debian Bookworm based) or if you're interested the Retrowave release is very nice. Both are available in 64 or 32 bit.
Admittedly, having Stable as the top-most page entry and Retrowave at the bottom of the list doesn't make much sense. Sorry for that! :cry:
I have updated the big "warning" banner of the stable download with a more bold message "do not use this version": https://www.elivecd.org/download/stable/
I've now downloaded the correct version :wink:
Thamks
