Can't move things around anymore using my touchscreen
Before, on my laptop, I was able to use my Touch Screen and move things around.
I was holding some key on the keyboard and could Press in the middle of the window and move it.
I could also Enlarge or reduce windows size, click icons etc
I lost that functionality...
If you had a guess, could it be one of the recent updates that created my problem or may be is some key combination I pressed that turned something off ?
Not that important to me but it was nice to use my touchscreen...
Tks !
Any guesses are welcome
That would be holding Ctrl+Alt and then moving the window or you need to "grab" the top bar of the window to move it.
If you have set i.e 2 or 3 finger tap as "right-click" then you'd get the resize options but ..... you can get those too by clicking/tapping in the small blue rectangle, top left of the window.....or by holding Ctrl and pinch to resize (depending on the application accepting it).
Practically your touch-screen should (at the least) have the same functionality as your touch-pad.
Tks will make more tests........
