Changing resolution in E16
can someone tell me howto fix screen rsolution on elive please I cant se the print
                   Type 'help' to know the ton of Elive features available...
~ ❯❯❯ inxi -F
System:
  Host: Elive-grumpy Kernel: 5.2.0-0.bpo.3-amd64 x86_64 bits: 64
  Desktop: N/A Distro: Elive 10 3.7.14 (alpha)
Machine:
  Type: Desktop System: LENOVO product: F0C20029TA
  v: ideacentre AIO 910-27ISH serial: <root required>
  Mobo: LENOVO model: 3647 v: SDK0K13468 WIN 3273581860483
  serial: <root required> UEFI [Legacy]: LENOVO v: O29KT21AUS
  date: 06/30/2017
CPU:
  Topology: Quad Core model: Intel Core i7-6700T bits: 64 type: MT MCP
  L2 cache: 8192 KiB
  Speed: 3406 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 3444 2: 3409
  3: 3467 4: 3440 5: 3520 6: 3450 7: 3575 8: 3473
Graphics:
  Device-1: Intel HD Graphics 530 driver: i915 v: kernel
  Device-2: NVIDIA GM107M [GeForce GTX 950M] driver: nouveau v: kernel
  Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
  resolution: 3840x2160~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2)
  v: 4.5 Mesa 18.3.6
Audio:
  Device-1: Intel 100 Series/C230 Series Family HD Audio
  driver: snd_hda_intel
  Sound Server: ALSA v: k5.2.0-0.bpo.3-amd64
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  driver: r8168
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: 98:ee:cb:51:e2:92
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  driver: ath10k_pci
  IF: wlp3s0 state: up mac: 94:e9:79:f4:3b:21
  Device-3: Qualcomm Atheros type: USB driver: btusb
Drives:
  Local Storage: total: 476.95 GiB used: 9.33 GiB (2.0%)
  ID-1: /dev/sda vendor: Samsung model: SSD 860 PRO 256GB size: 238.47 GiB
  ID-2: /dev/sdb vendor: LITE-ON model: L8H-256V2G size: 238.47 GiB
Partition:
  ID-1: / size: 217.93 GiB used: 9.33 GiB (4.3%) fs: ext4 dev: /dev/sda3
  ID-2: swap-1 size: 16.03 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors:
  Missing: Required tool sensors not installed. Check --recommends
Info:
  Processes: 193 Uptime: 19m Memory: 15.55 GiB used: 638.2 MiB (4.0%)
  Shell: zsh inxi: 3.0.32
its ok I found it
Nice.
But now you have explain ....
(Others could search for that ' solution', too...)
go to settings then screen settings click on that and follow the directions
