Conky does not show across multiple desktops E24
Conky does not show across multiple desktops in repo Enlightenment.
Yes I could start one instance per desktop...but that's kind of annoying to do. and it can't be automated.
How can I make conky stick on every desktop???
Do you want on every desktop a conky with the same content
Or
on every desktop a different conky...
:thinking: :popcorn:
I assume the same conky, as in, with e16 conky is shown at every single desktop with the exact same info. I'd like to do the same with E24
Found it
Just press CTRL-S while your focus is on conky
And it sticks to multiple desktops :slight_smile:
And it works for future launches is the best part !! :smiley:
