I have looked around all system parameters, enlightenment parameters but I didn't found where are the settings to the energy control. I would like to set a timeout for the screensaver to start and same thing for the screen blanking, suspend in memory and hibernation .
Did I missed it somewhere ?
There aren't any power settings specifically for E16, if at all you'll have to delve into the suspend/hibernate config files or install X11 versions for screensaver, etc.
On a laptop there's settings in 'laptop-mode-tools configuration' that can be altered i.e turned on/off but that's about it.
Thanks, I'll take a look at the config of laptop-mode-tool. The settings on the elive menu are only to turn on/off some modules. It's doesn't go any deeper. It's not what I need.
Regards,
Bernard.
