Just discovered this useful little tool to modify key bindings easily - wonder why its not in the menu by default? In terminal just run e16keyedit and the rest is pretty obvious...
they are included in the menus ![]()
but is better to edit the file manually since it provides more control and possibilities, you can see all of them directly on the comments of th efile:
scite ~/.e16/bindings.cfg
