Salutations and thank you for this GNU system its amazing.
One of the issues that I have to resolve is conectivity when and only when I lost my wifi at home (like now) or when traveling. I have always use easytether. I would need advise on this matter. Is there is any way to make easytether or any other platform to work?
Easytether pro from mobile-streams n works just fine on 1204 n 1404 but not on Elive.
With the latest update things kind of move alone but not really. It's making the connection but nothing displays...
Thank you
What does exactly easytether? it is like a "fallback to a different connection method" (like connecting with the phone when wifi fails) ?
Ooooh, I remember tethering, using my ol' Palm Treo.
One connected (tethered) the phone over USB (at first only serial) to a PC or laptop and then accessed it as a modem using AT strings.
Lots of provider (and country) specific modem strings that could go wrong.
Since Android has made it dead easy to just share a connection as a temporary hotspot I've happily pushed that from memory.
Elive included an own tool called 3g-dialer which you can found in the connections menu and it is very handy to use the providers configurations
but it has been not tested for around 10 years lol
