New Retowave 3.8.50, downloaded and installed on a Latitude E6430 i5, 8G ram laptop. Very nice design!!
Thank you Team Elive
unfortunately the screenshot is broken ![]()
I will repost tomorrow
How to get rid of “session restored” comment (seems others are silented ok but this one)?
As I’m fan of Silence! ![]()
IH!
Hi @Franc , which session restored you meant? after suspension?
After hibernation!
Ih!
Long time ago I had the idea to make a configurator for sounds and voices, to enable / disable them etc, this was never implemented.
Voices and sounds doesn’t not play after 9pm, by default ![]()
A simple solution for right now will be to use an environmental variable when running it, but then you must run it from terminal, so like:
SILENT=1 elive-pm hibernate
