Do you know if the current Beta version includes the needed driver for the HD 5500? I tried a 3.0.0 live image and was getting the 'no screen found' error, same as this post:
I'm using an old hp spectre x360 G1 which has an Intel HD 5500 for graphics.
This card was introduced 2015 so will not be available on 3.06. With some trickery it could be installed I suppose but probably will stumble on libraries.
The card will be supported by Beta which is of a later date.
