Hello everybody, I tried to download Elive 1.0 Gem.iso with the torrent but it’s not seeded anymore. does someone has it ? It would be great if anyone was able to share it.
Thanks a lot.
The Museum trackers no longer work (you can get it to work if you add other public trackers to your tracker list as I’m seeding it) but it is easier to just get the Gem ISO via torrent from archive.org. This has more than just Gem 1.0 but you can grab what you need from that. It is seeded and should download quickly.
https://archive.org/download/elive3.0/elive3.0_archive.torrent
it worked ! thanks a lot for your share
I didn’t know that the trackers doesn’t work
I saw that in the past but updated the torrent with a new one, it is meant that the torrent file should seed correctly, but @Homebrew_Theque used the new one if im not wrong (basically the one published on the website), and I was seeding yesterday but not noticed it sharing.
In any case, I will update the torrent again after the release of the next retrowave update
I tried the torrent from the website too, yesterday and it didn't work .... no connections/peers at all.
I also tried the atchive.org torrent which downloaded reasonably fast, so that's nice to know. ![]()
I was syncing disks, try again, let’s see if works, I will leave it running for 1-2 days.
