Enlightenment news and status [E27 or newer]
This thread is going to be used to announce things related to the new Enlightenment, so make sure to click in the “Watching” button if you want to be updated about this topic
:news: :happybounce:
I just updated the package of E27 (enlightenment) from updated upstream sources, this is the commits that happened on it since the last importing to the Elive package of Enlightenment:
  • 6d01e0bee - (8 days ago) Carsten Haitzler (Rasterman) — const char ptr warnings - silence (upstream/master, master)
  • 75325af64 - (8 days ago) Carsten Haitzler (Rasterman) — clipboard - back to wrapped elm win add
  • 3babddceb - (8 days ago) Carsten Haitzler (Rasterman) — clipboard - move ewin init to later to allow display to come up
  • 4b6742b65 - (8 days ago) Carsten Haitzler (Rasterman) — clipboard - delete elm win used for clipboard on mod shutdown
  • fa84f937c - (8 days ago) Carsten Haitzler (Rasterman) — dont use the elm_wiin_add macro wrapper
  • 65f0541b9 - (8 days ago) Carsten Haitzler (Rasterman) — add env var to force no gl in comp
  • 839ebb5a1 - (8 days ago) Carsten Haitzler (Rasterman) — allow env var to disable watchdog
  • 62c1af466 - (8 days ago) Carsten Haitzler (Rasterman) — e comp - make close button really exit e in e-in-a-window-wl mode
  • 0fca74851 - (9 days ago) Carsten Haitzler (Rasterman) — cpufreq - force a render of the inlined window for gradients
  • fff93ec18 - (9 days ago) Carsten Haitzler (Rasterman) — change handler protytype to not rely on 0 or more args
  • ff3bf99f8 - (13 days ago) Carsten Haitzler (Rasterman) — pid nice/pri - make this go up and down without cap_sys_nice
  • 30fd6d0eb - (3 weeks ago) maxerba — Updating french and italian translations
  • 37058c681 - (3 weeks ago) Carsten Haitzler (Rasterman) — mixer - warnings begone
  • 8ee2737d1 - (4 weeks ago) Carsten Haitzler (Rasterman) — mixer - add actions to set or next/prev sink
  • f5f93752b - (4 weeks ago) Carsten Haitzler (Rasterman) — clipboard - store type too
  • 019ff14ba - (4 weeks ago) Carsten Haitzler (Rasterman) — move all config fiddling entirely into e_mod_config.c
  • 086bd85f8 - (4 weeks ago) Carsten Haitzler (Rasterman) — clipboard - truncaate config already knows max - dont pass in
  • a875190e4 - (4 weeks ago) Carsten Haitzler (Rasterman) — cpufreq - allow up to 10s interval between polls, not just 1s
  • e029527a5 - (4 weeks ago) Carsten Haitzler (Rasterman) — system - cpufreq - ensure acpi profile set covers all possible options
  • 1707cc62b - (4 weeks ago) Alastair Poole — cpufreq: support all kernel-provided options.
  • 730bed1f1 - (4 weeks ago) Alastair Poole — cpufreq: Add ACPI cpufreq governor support.
  • cffaa4173 - (4 weeks ago) Carsten Haitzler (Rasterman) — e system - cpufreq - set gpu to match cpu power level for amdgpu
  • fbb28f52d - (5 weeks ago) Alastair Poole — AUTHORS: Update e-mail.
  • 649eb283d - (5 weeks ago) Carsten Haitzler (Rasterman) — reduce clipboard more
  • 8a2623658 - (6 weeks ago) Carsten Haitzler (Rasterman) — powersave - remove spurious extra write to powersave wake
  • 76bd545de - (6 weeks ago) Carsten Haitzler (Rasterman) — cpufreq - remove unused update timer in instance
  • f5fc3c18d - (6 weeks ago) Carsten Haitzler (Rasterman) — cpufreq - when in freeze eg scr off go slow in poll eg 60 sec
  • 200cca3dd - (6 weeks ago) maxerba — Adding french and italian translations
  • 777f82f6f - (6 weeks ago) Carsten Haitzler (Rasterman) — clipboard - tune list item layout
  • 84986c477 - (6 weeks ago) Carsten Haitzler (Rasterman) — clipboard - change default history to 10 - popup not so huge
  • f0b9e75c8 - (6 weeks ago) Carsten Haitzler (Rasterman) — clipboard - save after deleting an item
  • b4c5dd356 - (6 weeks ago) Carsten Haitzler (Rasterman) — clipboard - allow individual items in clipboard to be deleted
  • ea261c63c - (6 weeks ago) Carsten Haitzler (Rasterman) — clipboard - use theme for gadget + update mod icon
  • 950c1b7b4 - (6 weeks ago) Carsten Haitzler (Rasterman) — clipboard - move to elm genlist + buttons for popup
  • 747648ead - (7 weeks ago) Carsten Haitzler (Rasterman) — reduce config items ... also spotted bugs waiting XXXd them
  • 873937576 - (7 weeks ago) Carsten Haitzler (Rasterman) — clipboard - move history into clipboard cfg file..
  • 312eab6a6 - (7 weeks ago) Carsten Haitzler (Rasterman) — clipboard - remove nuked headers from meson build
  • 1e5750ad6 - (7 weeks ago) Carsten Haitzler (Rasterman) — handle action and instance tracking proeprly
  • e6a2dfc0c - (7 weeks ago) Carsten Haitzler (Rasterman) — add wltjr too to authors
  • 885c6f483 - (7 weeks ago) Carsten Haitzler (Rasterman) — trim down header count and use single master header
  • 581eea065 - (7 weeks ago) Carsten Haitzler (Rasterman) — rationalize includes to use single master e_mod_main.h
  • 2a8becdb8 - (7 weeks ago) Carsten Haitzler (Rasterman) — clipboard - remove custom logger
  • 26876d6da - (7 weeks ago) Carsten Haitzler (Rasterman) — clipboard - delay fetch of sel a bit to allow rapid changes to settle
  • 8f9730f71 - (7 weeks ago) Carsten Haitzler (Rasterman) — clipboard - reformat and clean up a bit
  • 33be48516 - (7 weeks ago) Carsten Haitzler (Rasterman) — Revert "unify formatting to vbe the same as e's formartting and consistent"
  • a2d4a9ef9 - (7 weeks ago) Carsten Haitzler (Rasterman) — unify formatting to vbe the same as e's formartting and consistent
  • 94f0d2ed2 - (7 weeks ago) Carsten Haitzler (Rasterman) — clipboard - fix worst warnings
  • d3812a822 - (8 weeks ago) Carsten Haitzler (Rasterman) — modules - clipboard - pull in as-is with just build fixes
  • 7c0201778 - (3 months ago) Carsten Haitzler (Rasterman) — battery - move udev battery/ac polling to thread
As you already know, just run: apui enlightenment
And remember: this is not yet an Elive polished E, its status is now basically a default/official E with a few Elive changes/features
Enjoy! :happybounce:
thank you, very much.
