I think the amazing terminal in Elive deserves a howto to show some of its features
First of all, make sure you open the terminology terminal, press Alt + ESC and write its name
- With Ctrl + Shift and C or V you can copy / paste like if was a graphical application
- With Ctrl + Shift and T you open a tab
- With Ctrl + Shift and PagUp or PagDown you can split it vertically and horizontally. You can also drag the limiters with your mouse to change the size
- Press Ctrl + Shift + Home and you have a compiz-like exposé effect to select a Tab
- Press Alt + Shift + g and your typing input goes to all opened tabs at the same time
- With Ctrl + Shift and h you have a miniview opened that you can easily scroll to a specific place
- Go to Settings -> Keys to know more of its hotkeys
You can also:
Open:
- open emails when clicking on them
- view the gravatar's image of an email when mouse-over it
- open web browser when clicking to an url (or copy it)
- view an image when clicking on its full path (Try: find . -type f -iname '*'png)
- reproduce views when clicking on the file full path
- open any file from its assigned app to launch from
Copy / paste:
- selecting with your mouse, you can drag your selection to be pasted elsewhere (with mouse middle click, or copy with ctrl + shift + c)
- with Ctrl pressed before to drag, you drag a boxed selection instead to follow your line, this is very useful when you want to copy a portion of contents and ignore the previous one, or from copying from an editor
Zoom
- Resize text using Ctrl and scroll button to resize the font to your liking
Own commands: Terminology has some own commands, for example:
- tybg: to set a background image for your terminal (or even a video!)
- tycat: just like "cat" to show the contents of a file, it shows the contents in your terminal like displaying an image or even a video, as a part of your terminal contents:
Not enough? just type "help" in your terminal of Elive and you will see a small intro of the possibilities and features available
Now, you know which distro includes the most powerful terminal ever
