how to shutdown elive 3.0 live from the GUI not via shutdown -h now ?
As we replied on the Chat, either
- Left Mouseclick at the desktop -> System -> shutdown
or - add a shutdown button on the screen by modifying one of the panel.
Yoda
1st method is simpler
Thank you,
so far I always used the right mouseclick as with most other Linuxes and so I could not find the "shutdown" ...
About the dock
I use it as follows :
- I start a new application and drag it in the dock
- to remove an item from the dock I just drag it out of there
Is that the proper way to handle the dock ?
Regards.
