Hi, I have an old computer with 192mb of RAM and a 600mhz AMD processor. Which version is compatible with my hardware?
Thanks in advance
Stable should run...barely...if it's too slow try an earlier version. I'd suggest on that machine using Gem (1.0) or earlier.
If you want to download a specific version without downloading the entire library of old versions, instead of going to the Old Versions link on the elive site go to this link, scroll down, click ISO IMAGE, and choose the one you want. ![]()
Really thanks, I'll try ![]()
