Higher quality of startup sound
Hello, ever since I first got recommended to try elive, I fell in love with the startup sound named "Topaz" I think. I found it in the files and used on my other non elive machines. But I always wondered if there is a higher quality version in FLAC or WAV or ALAC. Can someone help me find a high res quality version?
The one that says "eeeelive" ? it was created by @roxville , i think that's the only version we have on its highest quality.
Maybe we can use AI (or in the future) to make it improved quality / HQ, if it doesn't add a copyright thing.
Or, maybe you mean this one?
mpv /usr/share/sounds/elive/elive-wm-login.mp3
If you want to switch between the elive startup sounds, you can simply use this command:
elive-startup-sound -c
These are the ones im looking for: /usr/share/sounds/elive/eliva-wm-login.mp3 and /usr/share/sounds/elive/elive-wm-login.mp3
They both sound amazing!
I think I will switch the default startup song to the one that says "eeelive", seems like to be the prefered one and its also very identifying with the distro :slight_smile: , yes this one has been made by @roxville
