Hi, Everyone!
I like default sounds theme in Elive, but not all.
I would like to turn off some sounds: by switching desktops, by close applcation end so on.
How I can do it?
Assuming you're on E16:
- Right click or middle-click the desktop background
- Click Settings
- Click Sounds
- Uncheck "Enable sounds"
- Click OK
This way is disable all sounds.
I would like disable only some sounds: sound by close app, sound by change desktop screen, sound by minimize window.
Or change these sounds to others
I found all sounds in these folders:
/usr/share/sounds/
/usr/share/e16/themes/Elive_Dark/sound/samples/
After remove some files some sounds are off
