How to install Signal ? Possible?
curl -s https://updates.signal.org/desktop/apt/keys.asc | sudo apt-key add -
echo "deb [arch=amd64] https://updates.signal.org/desktop/apt xenial main" | sudo tee -a /etc/apt/sources.list.d/signal-xenial.list
sudo apt update && sudo apt install signal-desktop
OOps, just noticed it is 64bits
Yes that's the correct way to install Signal. Works great; access to chats, audio and video calls just like the mobile app. Love the privacy.
Yeah, unfortunately 32-bit support is dying.
This one is good too but no 32 Bits Download – Threema
