Multiple users?
As you know in Elive it is very easy to use multiple users at the same time, you need just to hit the launcher and type "user switch" and you will find this feature. After that you can switch between them in a faster way using "Ctrl + Alt + F8" and other numbers like F7, F9, etc. for each user
Unfortunately, pulsaudio only works for a single (first) user by default, this is probably due to security reasons (other users listening what is happening in the other users running the same machine), to make it correctly working with different users at the same time you need to configure pulseaudio to use the same socket for all the users.
Files to edit
Run this command
~ ❯❯❯ sudo scite /etc/pulse/default.pa
And change the line which says
load-module module-native-protocol-unix
with:
load-module module-native-protocol-unix auth-group=audio socket=/tmp/pulse-server
Also, edit this file:
~ ❯❯❯ sudo scite /etc/pulse/client.conf
And in the end of it, add these lines:
autospawn = no
default-server = unix:/tmp/pulse-server
enable-memfd = yes
Now, just run from each user
~ ❯❯❯ pulseaudio -k ; pulseaudio -D
Yepeee! ![]()
Question: do you think this option should be set by default in Elive? ![]()
