I use a lot the Iconify function
Usually my apps's thumbnails go on the top of the screen
But I must have pressed something as it's not there anymore...
tks !
tks !
check in your E16 menus (not the configuration panel), you should have an option to create a new systray gadget
Tks I created a IconBox and it did the job
