Installer module page should NOT use wordpress
Trying out 2.0 here, and it requires an installermodule. So it fired up Iceweasel, and I couldnt see which fields were which - I had to boot up chrome and load the page, just to see which field was email and which was promo code etc.
I think that the installer-module page should not use wordpress, it should use just a custom or old website specially designed for it, so that iceweasel works.
BTW: Going to try palemoon "soon". I just extracted with asn online tool that works with chrome - theres nothing built in for xz's. (Unrar online, Unzip online, unzip, unrar, rar, rar5, extract online, uncompress files, archive - B1)
Yes there is. I've got "xzcat" of which I pipe the output. :+1:
on 2.0?
Well anyway, I extracted it, and there's a missing dependency. I didn't want to muck around too much but someone else can try if they really want.
No, I missed that. :man_facepalming:
There should be a lot considering how old it is.
Is this fixed now? I have been working on that page recently, tell me if displays correctly otherwise I can try to remove more "new css3/html5 codes" that should be the cause
Sorry, can't test. Don't have a 2.0 installation disc and pressed for time right now.
The best way to test with a non html5 browser and check if it renders stuff correctly is to open it with "netsurf".
I've got it installed for solely that reason. :smile_cat:
they do have a bunch of html5 and css3 stuff tho iirc. using the browsers that would be actually used would be more accurate.
Going for worst case scenario is always best.
Did I mention links2 ?
:smile_cat:
