This thread is made for the people to subscribe / follow it if they wants to know the updates on the installer features
mentions: @triantares @TheTechRobo @linux23dragon @yoda @Franc @zbd ...
Now the installer will automatically create a swap file in the root partition if there's enough space to add it and there was not a swap partition added, this allows to:
If you want to try it, just run the installer which will be automatically updated
Note: must have "same amount as RAM + 10 gb" of free space in the root partition in order to be automatically added, the swapfile size will be the same amount of RAM + a few MB more. Also this will only be added if you don't have an already swap partition to use
Am I misunderstood something or:
-What if having 1Go of RAM? Needs 11Go swap??? Always reads about swap=RAM or =RAMx2..?
-As your write it, what if having 64Go of RAM? Means 74Go of swap???
edited, check if is more clear now
I just reverted back to Elive Retrowave, and found that the swap partition was correctly installed automaticly.
Thank you
No, I read that it minimally requires 10Gb more of free diskspace than available RAM for the swapfile to automatically be created.
I personally think RAM+10Gb is a bit over the top if there's 64Gb of RAM ....... for hibernation 2Gb should easily suffice. ![]()
So IMO a fixed max 4GB swapfile size should be more than enough for hibernation on the current Elive systems.
That would mean needing 14Gb extra space in the root file system on a freshly installed system. Which still sounds a lot but makes sense. ![]()
Then please stop the installer's automatic partitioning from giving me a 40GiB root partition ://
Wait what? You want it bigger or smaller? ![]()
For a first install including a swap-file, you'd need 8-9Gb Elive-system + swapfile-space (4gb+10) = 23Gb as an absolute minimum.
Bigger... my root partition keeps filling up.
Well you should clean out the "/var" directory more often or ...... set up a separate partition and mount it as "/var".
Or do you have "/home" in there as well?
I mean I've got an upgraded 3.8.30 here with external programs in "/opt" and a lot installed as .deb apps and its about 18G (including "/var"). ![]()
You mean to mix the /home and the root partition in a single one? This can be a wise option too (we don't necessarily need a separated /home at all)
That would be very unwise IMO.
If you do a full fresh install with /home in the same partition as "/", you lose all your personal stuff because it gets reformatted.
Along the same line: We might as well remove the "persistent" option from the live-USB and keep one partition....it isn't nescessary. ![]()
I prefer separate swap partition in automatic mode, while installing Elive
Isn’t there upgrade mode?
Yes, there is but sometimes there's so much cruft and stuff gathered that a fresh install is needed.
Especially if it's for testing.
IMO if there's cruft in the system as a whole, the home directory isn't going to be in a great state either.
Yeah, but that is simply solved by creating another new user with default $HOME settings.
Elive doesn't works on that way:
Note that we are debating if should be better to integrate the /home into / for simplicity, this will save cases like the one of @TheTechRobo that finds his root full, and Elive doesn't needs a separate /home because it controls it quite good... On the other hand, if a user is more "expert" and want to customize things on its own (@triantares case of separated /home) then you don't need to use the auto install mode but the custom (manual partitioning) one, also remember that you are arguing about advanced usages of the /home which still, a user that needs "auto" mode doesn't knows/understand how to manage a separated /home or for what. Remember that in the end, the installer always have "upgrade mode" which does a clean install without damaging the home directory & users & settings
What?
This is not the point of the persistence boot: https://www.youtube.com/watch?v=9EfqL8D76xY&pp=ygUiZWxpdmUgcGVyc2lzdGVuY2UgdHJhdmVsIGxpbnV4IHVzYg%3D%3D
this still the actual case ![]()
I was being "tongue in cheek" there. ![]()
What if there was an option for a separated /home like how Debian does it?
