Hello all,
I did a successful fresh install of Elive 3.0.6 on Asus Eee PC 1015P Seashell;
with SSD, Intel GMA 3150 chipset, huge 1GB RAM, Intel Atom N450 / 1.66 GHz
- after the login screen the display shows black (but still on) and so I came to the idea
to connect an external display via dsub cable - and strange - I had to learn
that it is the only main display. So I struggled around for a while and found
"Screen Layout Editor" but it shows the 'default' monitor only - which is the
connected external display but with the values from the internal screen.
For some reason it does not recognize the internal notebook display after login anymore...
Can someone help, pls ?
(before it was running LM 18.1 Xfce, without problems - so hardware seems ok)
(on other notebooks, e.g. HP Mini with VIA chipset, with same install no problems of this kind has appeared)
Krgds
and best regards to Thanatermesis - I adore your work and concept,
will talk later more to ya ![]()
