I used sudo apt-get install keepass2 to install a password manager I use
It worked but does not work well under elive
I am used to ubuntu PPA repository etc
If debian let me install kepass2 it mean that it was in some kind of authorized repository.
Where can we see what app are approved to be installed on Debian / wheezy ?
Exemple i would like to install KeepassXC that works even better for me in Ubuntu, but in Elive, I am not sure where to start.
jlive
September 5, 2018, 9:47am
2
Ive installed keepass2 from debian wheezy backports.
It works nice.
yoda
September 5, 2018, 2:35pm
3
Could you tell me step by step how you did ?
Yoda
I have been using linux for a while, but, I come from the Windows world...
jlive
September 5, 2018, 3:01pm
4
You need the full wheezy repos, with security updates then I got no more dependency unmets.
edit /etc/apt/sources.list.d/debian.list with this content:
deb http://ftp.debian.org/debian wheezy-backports main contrib non-free
deb http://ftp.debian.org/debian/ wheezy main contrib non-free
deb http://security.debian.org/ wheezy/updates main contrib non-free
save the file and:
apt-get update
start keepass2 and open your .kdbx file
yoda
September 10, 2018, 7:39pm
5
Hi
I don't know if you tried it to help me or if you were already trying it but let me explain one issue I have
Normally when Keepass is well integrated in the OS, we can COPY the password from the keepass app and PASTE it where we need that password
The COPY within keepass does not work...So we can't paste it in the needed site or app.
It is sure we can display, and type it manually thought... Better than nothing
