Yes, but this was been greatly improved some months ago:
Fonts automated selection and sizing based in your type of screen, resolution and dpi, also includes desktop scaling factor
In other words: the resulting fonts configuration should mesure exactly 2 milimeters height for a CAPS letter (for example in thunar), this is the optimal size for human eyes and it's exactly the same sizes Apple uses for their phones and computers, which sizes you have? (not very easy to mesure but it can be done)
Next time I install Elive, and use configuration windows etc I will pay more attention for which window I was having problems with, with my 50 years old’s eyes
I just tried the last 2.9.99 build in a laptop which requires "bigger fonts", and alright, they are SMALL, and in fact you can see other elements with a correct "bigger" font but not in the GTK applications (like widgets or the thunar filemanager) seems like there's a bug, i will try to fix that
Actually the Auto detection mode works good, but for the GTK applications was set to a bit small for some unknown reason, a font size of 2.0 mm it’s sized to 1.2 in (my) laptop, which has 157 dots-per-inch
nothing :), just run “apug” and restart to a new desktop configuration if you want to have the fonts improved (not a very important thing to restart desktop configurations)
if you use persistence, run apug and the new version of e17 will be included statically to your usb
