Lost keyboard volume functionnality
I updated .config to the last version and had to redo some stuff
But happen to loose my Logitech Volume Key, Mute in the process.
I tried the exec setvolume 5 up and down and mute but it doesn't work
@Thanatermesis ?
using elive-skel upgrade and choosing .config then RESTARTING the Desktop config
OK if i use the Audio configurator and choose my Logitech HeadSet, the Keys starts working again
It's only if I set pulse audio to use the speakers / line out, than volume key / mute do not work
may be (!) it's switching strangely because of an available HDMI out - port ?
What when you try to disable the inactive out?
(HDMI should be grayed out, when you are using line out jack...
:omfg:
if I go into Pulse Audio, the HEadSet Mic do not show / is not visible in Input Devices
Then something went wrong with the driver
:anxious_face_with_sweat::fearful::downcast_face_with_sweat:
ok I'll keep using the Headset for now
The only problem is that I can't controle volume when using LineOut / speaker
Some rebotos and apugs in a week it'll come back LOL
yes, .config is a generic dir of multiple configs, you should update the directories inside them independently, not the full dir
ok this entry should be not shown by default... removed
@yoda:
Ok, let's know if the issue is with the elive mixer tool or from the mixer's itself, try these two commands and tell me which ones works correctly for your issue:
pulsemixer --set-volume 40
setvolume 40%
both will change the volume at the 40% volume level (see if the volume changes when using these commands)
but works very well.
tks
which ones of these two ones? :slight_smile: aparently one of these fails to change volume in your machine
but commands works
Though, it's was wit the headset the problem, so I need to do more testing
