Continuing the discussion from Youtube-dl GUI finished:
What makes it ugly? The buttons? I find that if the buttons are better it looks fine. ![]()
the buttons are defined by the OS AFAIK, it's more the general options, widget outlines, coloring and spacing (it's cramped) that I dislike.
Qt5 and GTK3 have a lot more to offer.
oh yeah, I forgot. the linux define looks like win95 tho.
I'll try out qt. Seems complicated tho.
Use "pyside2" to be able to use python like code as Qt5 is C# oriented.
That way it'll all come easier and on top, like I mentioned before: "QtCreator" is excelent, just requires getting used to "signals and slots" as a means to have a GUI communicate with it's surroundings.
It really is very well thought out. ![]()
