Hi. Elive 3.8.8 x64 was recently installed. I use the mouse for my left hand and can't find the necessary setting .How do I change my settings ?
Welcome to the community! We're glad you're here ![]()
Hmm, I can't seem to find it either. The best I could find was the Trackpad config (in the settings menu item) ![]()
In a terminal:
xmodmap -e "pointer = 3 2 1"
If you want to keep this for every loggin, append that line to ~/.bashrc or ~/.zshrc
Ok ! Maybe I could make a script that does it FOR you..
Thx ![]()
Thanks. This works on my computer.
@triantares, @UserMutus this works on touchpad too? If so, maybe it could be implemented in the elive touchpad configurator as an extra option ![]()
