Imagemagick is installed but I cannot open it, while pooking around I found brasaro but not imagemagick, tried to run it from command line but no luck.How do I open imagemagick?
Actually I just need to write a bootable iso to usb donât care which burner I use but imagemagick shows to be installed, I cannot find it though nor can I start it from the command line. I must be overlooking something simple, simple is usually what kills me.
Hi Tommy,
Imagemagick is a cmd Image (picture) manipulation Tool. Mostly known as visible result is the command âdisplayâ. But you will never be able to see an image (CD/DVD/BD copy).
In most cases youâll need âddâ, to copy an image (CD/DVD/BD copy) to a USB Stick. Sometimes this wonât work (for bootable), but most times the project itself write in the documentation what and how to use.
Yes sorry I realize my error, what I need is Image-Writer, or Etcher to burn iso to usb but cannot find those files in synaptic.
Tried to sudo apt-get install still no luck.
How do I burn .iso to usb with having to âddâ, really donât remember how to do that.
to keep the forum clean and organized, with useful information to others; since this was originally a wrong post, i will delete it
everybody agree?
