No usb nor internal microphone sound in hp laptop kabylake
No usb microphone sound... please help
@MESSENGER_OF_ELOHIM
First of all
Welcome in our community :hug:
For that we can understand your issue
we do need a bit more details about your situation over there, pls:
Which variant of Elive
Model of your Computer
Livemode or installed to disk
Looking forward to your reply
Krgds
As @Rebel450 said, we need a bit more info to help you.
One thing that helps me a LOT with mic issues is going to Elive Menu > Audio (or Sound) > Volume Controland from there find the tab Input Devices. Here you can tailor pulseaudio settings :innocent:
(You might see Show All Except Monitors at the bottom...a monitor is just in case you want to record your speaker output, you direct the application to record Monitor of _____ rather than ____. So Show All Except Monitors WON'T show the monitors. Useful if you don't want the clutter of two entries per sound card.)
sorry for bump...I just set my New option on this forum to be every single topic i havent seen so i'm going through every single one to lower the dozens (!!) of threads in my feed
