Hi. Elive newcomer here. I've just installed Elive 3.0.4 32bit on a old computer (AMD XP 2000 and Geforce 6800 (NV40) ).
Seems to work just fine. Because I intend to use it for presentation, I figured out that current Libre Office was little too old version, so I figured Open Office still have a 32bit version for debian.
Therefore I went ahead to the [Open Office web site downloaded the package.
Then I followed this guideline openoffice.com/download/common/instructions(cannot post links and no workaround) fixed by @TheTechRobo
--> Look at the botton of the page, under " Linux DEB-based Installation"
The files are located where I can find them, and I've also made links to the shell scripts files as the guide suggested.
Working
I can open about any of the shell scripts under /opt/openoffice4/program from within the file explorer, and it runs just fine.
Not working
After installing Open Office, it didn't make any updates to the menu. I have searched on the web but I cannot find a guide on how to manually manipulate/add a new item to the menu.
Also, when try to Run everything --> soffice, it says
Blockquote
Application run error
Enlightenment was unable to run the application
soffice
Blockquote
You can create a the command "soffice" yourself in i.e "/usr/bin" or "/usr/share/bin" and link it to the soffice comnand in /opt/
That way you wont need to keep using the full path.
This would probably be the solution to your second niggle too.
