Peek screen recorder
I need for my work to create Animated Gif
I usually use Peek from the Debian Repo.
For I don't know what reason, if I open the peek Window, I can click, interact with my Applications, within the Peek frame..
If there is anyone using peek, do you have the same problem ?
What is weird, I used it before within Elive / Buster... May be some update broke something...
if you have the animated images in multiple files, just try:
and you have test.gif animated :slight_smile:
no sorry
I will figure out why it stopped working
tks though
Another amazing feature :eyepopping::happy:
