Periodic loss of mouse wheel scrolling ability
Be aware that if the window is set to 'fixed position' or 'fixed size' it will not move or resize unless that setting is toggled.
That 'toggle' option (and a few more) can be found by Alt,Ctrl+Right-click (or the blue icon top-left in the title-bar)and right at the bottom of the menu under the "miscellaneous" category.
Maybe they're NOT so un-related. Check the memory post. I just got hit again with no mouse wheel scrolling. Not a major event, went to another tab and no problem, went back, no problem. But it DID occur. Still. :frowning:
EDIT: HMMMMM!!! This time, it happened in a nemo folder view (@triantares had mentioned thunar). Whilst trying to scroll, I could see little (directional?) icons up-left of the pointer and a big red X low-right of the pointer. Moving the pointer to the window vertical scroll bar and moving it restored the mouse scroll wheel use.
Just rep'ed the issue. I had nemo open, went to my documents location where I was correcting the "browsers-in-RAM /etc/fstab" implementation. I hadn't saved the file, but pointed nemo to my home folder and into the .cache directory to look at the properties of some of the folders in there (to see how much space each cache folder represented). After looking at several of these, the scroll problem happened again. The little "icon" I mentioned above is a pointer icon. This time, grabbing the window scroll bar to scroll was not immediately easy. Had to do it 2 or 3 times before it worked.
I dunno if you have to have a related file-manager-launched file still open and with pending changes to have the problem occur, but since it did the first time, that's what I did this time.
HTH.
It's something I've got almost all the time (file-manager-launched file still open), many of them even. So I'm not too sure about that. :thinking:
I haven't been hit yet again but ... time will tell.
This is a long thread, I didn't read it, but I have some similar problem in my E16 setup where the cause I think is google chrome.
Anybody found the cause of the issue ?
For now, on my machine it looks like enabling the native system title bar alleviates the issue.
Same here for browsers. I have a similar but different issue on nemo that I can rep.
And sometimes I think the same using thunar (I can't fixate it, alas) but the out-time somehow seems shorter. That could be wishful thinking, though.
AAAARRRRGGGGHHHH! Just saw that the post was modified so opened it. Guess what?
Scroll wheel doesn't work.
And yeah, I've got the native window title bar thing set.
Back to the drawing board, @triantares ....
EDIT: I kept having the issue in this browser tab no matter if I went back to the previous page (Backspace, Alt-left, etc.). Clicking on another tab fixed it, both there and back here. And again, I could see the li'l cursor and X as I reported about the issue in nemo.
FURTHER EDIT: I'm now wondering if this scroll wheel problem only occurs in this forum.
Most certainly! It looks to be an Elive issue, so why report it anywhere else? :thinking:
I've seen it coming back too ..... but still no clear clue as to what's causing it.
It happens when I switch tab sometimes, then the scroll doesn't work straight away and automatically I move the mouse and scroll again, and again ...... after which it usually comes again.
Those actions are done without thinking, in reflex and mostly not even really noticeable. It's only a few moments later I realize: "Hey, my scroll was gone there!". No logs, no errors, naught .... save maybe an overly stressed system. :thinking:
PS (for @Thanatermesis ),
There are also random short moments where my touchpad seems overly sensitive.
Ditto. Most peculiar, mama! Strange days indeed!
Okay, as @triantares made me look in another post, I AM on Trixie, but my repositories aren't. Not sure how or if that could play into this issue. So from way above to down here, correct me if I'm wrong:
I've had it in my Vivaldi browser, mostly it seems in the forum. The change to the native window title bar did indeed seem to help for a while. But as stated above, it's occurred again. I've also seen it in nemo (steps for me to rep shown somewhere above).
@triantares has seen it in both browser sessions and in thunar. Using multi-fingered touchpad scrolling (what touchpad? I have a sorry Elantech but don't really use it much).
@earl31515 has seen it in whatsapp and telegram (nowhere else, Earl?). I couldn't tell from his inxi output what type of t-pad, mouse, or trackball was in use. Not sure that it matters.
@Thanatermesis has seen it -- where?
There's got to be some commonality here.
I'm on "Trixie" but not my repos, apparently. I'm on Elive 3.8.52 Pro retrowave, e16 ("1.0.31").
We can't be the only ones with this problem. Hope someone else will chime in and add to the knowledge base!
Which means you're most certainly NOT on a Trixie-base, hence me asking about the output of elive-version and 'inxi -r'.
Might as well add 'uname -r" to that list as well. I'm on '7.2.6+deb13-amd64'
Anyway, it's fairly clear now that this mouse issue is not E16/E27, systemd/openrc or Bookworm/Trixie based nor a specific browser.
Yup!!! Does look that way.
A thought just crossed my mind:
This delayed behavior would be deemed normal when using a keyboard.
Could there be some mixing up of signals?
Just popping in to report that i've had this too and usually only with Thunar. Cant remember that browsers or other programs are affected. But usually just switching window or "minimizing it to titlebar" with scrollwheel and then back helps. Or Alt+tab to other window and then back helps.
And sometime my windows are placed outside of screen and just showing just a tiny edge or corner. But that's usually because the program itself was minimized to background and then it opens a windows and places that offscreen while opening its own window ok. Then i just grab the visible part of the window with Left Win key + left mousebutton and move to back to screen.
Small quirks but bareable :slight_smile:
