Write here all the problems or bugs that you can see on this website, if any! We need to know them to make the website correctly working for when we open it public-massively ![]()
There was a rare problem with the urls with double slashes like: https://forum.elivelinux.org// , giving a blank page
Now it is FIXED by removing all double slashes from any url formation (this could lead to other bugs, but is not common to use // , so please report any broken url :))
@subrms are you familiar with iptables? seems like the server is blocking some connections by the forum
There was a problem with the email server, seems to be working now!
Make sure that you are subscribed to this thread: @yoda
Excuse me for the delayed answer. Yes i can help for the iptables
These are some messages that i see in the logs for the localhost ip:
Jul 17 09:53:31 hostdo2 kernel: [48374.397423] iptables denied: IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=127.0.0.1 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=60229 DF PROTO=TCP SPT=53680 DPT=25 WINDOW=43690 RES=0x00 SYN URGP=0
Jul 17 09:55:31 hostdo2 kernel: [48494.406997] iptables denied: IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=127.0.0.1 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=34326 DF PROTO=TCP SPT=54032 DPT=25 WINDOW=43690 RES=0x00 SYN URGP=0
and these for the ip of the container of this forum:
Jul 17 01:31:51 hostdo2 kernel: [18274.790246] iptables denied: IN=docker0 OUT= PHYSIN=veth9d774a2 MAC=02:42:c8:d1:75:5a:02:66:a2:94:39:bd:08:00 SRC=172.17.0.2 DST=138.68.75.234 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=34769 DF PROTO=TCP SPT=38682 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Jul 17 09:30:21 hostdo2 kernel: [46984.984094] iptables denied: IN=docker0 OUT= PHYSIN=veth037e8a5 MAC=02:42:c8:d1:75:5a:02:66:a2:94:39:bd:08:00 SRC=172.17.0.2 DST=138.68.75.234 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=12698 DF PROTO=TCP SPT=36680 DPT=587 WINDOW=29200 RES=0x00 SYN URGP=0
Jul 17 10:04:55 hostdo2 kernel: [49058.674660] iptables denied: IN=docker0 OUT= PHYSIN=veth037e8a5 MAC=02:42:c8:d1:75:5a:02:66:a2:94:39:bd:08:00 SRC=172.17.0.2 DST=138.68.75.234 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=51819 DF PROTO=TCP SPT=40204 DPT=587 WINDOW=29200 RES=0x00 SYN URGP=0
And this is the iptables configurations made for the server:
enable all outgoing traffic
iptables -P OUTPUT ACCEPT
disable ipv6 ssh' attempts, important
ip6tables -t filter -A INPUT -p tcp --dport 22 -j DROP
block null packets
iptables -A INPUT -p tcp --tcp-flags ALL NONE -j DROP
reject syn-flood attack
iptables -A INPUT -p tcp ! --syn -m state --state NEW -j DROP
reject x-mas packets
iptables -A INPUT -p tcp --tcp-flags ALL ALL -j DROP
accept needed services
iptables -A INPUT -i lo -j ACCEPT
iptables -A OUTPUT -o lo -j ACCEPT
iptables -A INPUT -p tcp -m tcp --dport 22 -j ACCEPT
iptables -A INPUT -p tcp -m tcp --dport 80 -j ACCEPT
iptables -A INPUT -p tcp -m tcp --dport 443 -j ACCEPTdiscourse (docker container) uses this ip: 172.17.0.2
iptables -A INPUT -p tcp -s 172.17.0.2 -j ACCEPT
iptables -A INPUT -p tcp -s 172.17.0.2 --dport 587 -j ACCEPT
#iptables -A INPUT -p tcp -s 172.17.0.0/16 -j ACCEPTthese are ports specific for nginx reverse proxy & ssl configurations
iptables -A INPUT -p tcp -m tcp --dport 25654 -j ACCEPT
iptables -A INPUT -p tcp -m tcp --dport 25655 -j ACCEPTallow all communication with the docker:
iptables -A FORWARD -i docker0 -o eth0 -j ACCEPT
iptables -A FORWARD -i eth0 -o docker0 -j ACCEPTsend dropped packets to syslog
iptables -I INPUT 5 -m limit --limit 5/min -j LOG --log-prefix "iptables denied: " --log-level 7
only give access to mysql from localhost (already configured default debian aparently)
#iptables -A INPUT -p tcp --dport 3306 -s 127.0.0.1 -d 127.0.0.1 -j ACCEPT
allow pings
iptables -A INPUT -p icmp --icmp-type echo-request -j ACCEPT
iptables -A OUTPUT -p icmp --icmp-type echo-reply -j ACCEPTaccept all packet who come from "lo", lo is always localhost
we need to add one more rule that will allow us to use outgoing connections (ie. ping from VPS or run software updates);
iptables -A INPUT -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT
iptables -I INPUT -m state --state ESTABLISHED,RELATED -j ACCEPTIt will allow any established outgoing connections to receive replies from the VPS on the other side of that connection. When we have it all set up, we will block everything else, and allow all outgoing connections.
iptables -P INPUT DROP
Finally, there's also the fail2ban daemon, which adds iptables rules (maybe you need to see a dump of the running iptables rules?), but it should not block anything by default unless there has been failed attempts IMHO
@yoda whisper test 2
Emails reconfigurations topic:
- Now the email can receive, so the website can listen "everything"
- this is good because bounces can be tracked (admin -> emails -> bouncing) and admins can have a notification in case of errors (must!)
- optionally we can answer via email, the option is enabled but better to not use it since includes extra quoted previous contents
whisper test @Thanatermesis and @grottem
