Sometimes jingles just "come" to me. That was the case for Elive...I thought of a cool jingle.
Unfortunately it sounds best with elivelinux.org rather than elivecd.org (sounds more natural and less forced), but users would get confused if they ended up at the forum rather than the website.
So...can we redirect elivelinux to elivecd?
To be honest
elivecd confused me, too.
But Thana.... he emphasizes that Elive is a LiveCdDistro; a sort of that..
Personally I like your suggestion, but
Btw: Which jingle
Here's the PDF. hope you enjoy.
The_Jingle.pdf | DocDroid
...even though the old elive logo said "more of a distro than a livecd"...
LOL
unfortunately am too blond to read notations, but my kids, they can...
Have to wait until 2morrow morning, then they can sing it for me
Haha there's an open source tool called Musescore that when you open the file it lets you press play and a voice hums the tune...and you can look at the lyrics...provided you're not too "blond" for that
here's the musescore file: http://www.mediafire.com/file/qkdgwejjgx0i177/The_Jingle.mscz/file
here's a link to musescore: https://musescore.org
There's quite a bit of ambiguity in the "live-CD or not" sense ..... but all the repos are named as elivecd too which I suspect is related to the repos on the live/install cd naming scheme and the install scripts on it.
By itself I'd say EliveLinux sounds fine but there'll surely be purists who say that it should be: GnuEliveLinux.
not exactly, i preffer elivelinux.org than elivecd.org, but the domain has a "reputation" of 16 years old (or more), so its a good thing to maintain for SEO reasons, also the moving means a major change in dns's and stuff so this means a lot work to do and investigate in long term (redirections, old contents / links in old websites, etc etc)
in fact since im not expert in seo i dont even know if is a good or bad thing to redirect elivelinux.org to elivecd.org (duplicated content, etc)
im not an expert but im fairly certain that a Moved Permanenetly redirect would be fine.
But get an expert's advice about that.
