Reiser4, futuristic FileSystem from outer space!
This thread is about betatesting and playing with the Reiser4 filesystem for your installs :slight_smile:
Reiser4 FS Intro:
  • Reiser4 is the fastest filesystem, and here are the benchmarks.
  • Reiser4 is an atomic filesystem, which means that your filesystem operations either entirely occur, or they entirely don't, and they don't corrupt due to half occuring. We do this without significant performance losses, because we invented algorithms to do it without copying the data twice.
  • Reiser4 uses dancing trees, which obsolete the balanced tree algorithms used in databases (see farther down). This makes Reiser4 more space efficient than other filesystems because we squish small files together rather than wasting space due to block alignment like they do. It also means that Reiser4 scales better than any other filesystem. Do you want a million files in a directory, and want to create them fast? No problem.
  • Reiser4 is based on plugins, which means that it will attract many outside contributors, and you'll be able to upgrade to their innovations without reformatting your disk. If you like to code, you'll really like plugins....
  • Reiser4 is architected for military grade security. You'll find it is easy to audit the code, and that assertions guard the entrance to every function.
  • Reiser4 provides the most efficient disk space usage among all file systems in all scenarios and workloads. In particular, on Compilebench ((c) Oracle) Reiser4 shows disk space efficiency 50 times (5000%) better than ext4, and 12 times (1200%) better than Btrfs with compression. The problem of internal fragmentation in Reiser4 is completely resolved by using a special technique of liquid records (or virtual keys).
Astonishing why's
Reiser Version 4 deep and detailed description
Security of data (checksums)
I'm just in shock! with some local test results :eyepopping:
So I created an image file (acting like a partition), and first I was surprised about the size used, the funny thing is that looked like with reiser4 it required more space, but then I realized that reiser4 was simply reporting the sizes correctly while btrfs not, and also btrfs uses much more of space than reiser4 using the same compression :rofl2: :-1:
root /tmp ❯❯❯ dd if=/dev/zero of=test.img bs=8M count=80
80+0 records in
80+0 records out
671088640 bytes (671 MB, 640 MiB) copied, 0.364203 s, 1.8 GB/s
root /tmp ❯❯❯ mkfs.reiser4 -yf -o create=ccreg40,compress=zstd1 test.img
root /tmp ❯❯❯ mount test.img mountpoint/
root /tmp ❯❯❯ mount | grep mountpoint
/tmp/test.img on /tmp/mountpoint type reiser4 (rw,relatime,atom_max_size=0x73f09,atom_max_age=0x249f0,atom_min_size=0x100,atom_max_flushers=0x1,cbk_cache_slots=0x10)
root /tmp ❯❯❯ du -hs /etc/ /usr/include/ /usr/src/ /boot/
33M /etc/
108M /usr/include/
118M /usr/src/
196M /boot/
root /tmp ❯❯❯ cp -a /etc/ /usr/include/ /usr/src/ /boot/ mountpoint/
root /tmp ❯❯❯ du -hs mountpoint/*
212M mountpoint/boot
211M mountpoint/etc
633M mountpoint/include
945M mountpoint/src
root /tmp ❯❯❯ df | grep mountpoint
/dev/loop0 622720 271160 351560 44% /tmp/mountpoint
The original files where located in my actual btrfs+compression(zstd) installed filesystem, they reports as having small sizes and after to copy them to the reiser4 mount they looks bigger, why? let's see:
In any case, (212 + 211 + 633 + 945) = 2GB, this should be size that these files should occupy, while it is using only 271MB as "df" shows, so "2000MB of files stored in a 271MB space", hum!
What happens if we do the same on btrfs with the same compression?
196M mountpoint/boot
33M mountpoint/etc
108M mountpoint/include
118M mountpoint/src
/dev/loop0 655360 339516 191236 64% /tmp/mountpoint
/tmp/test.img on /tmp/mountpoint type btrfs (rw,relatime,compress=zstd,space_cache,subvolid=5,subvol=/)
The sizes by "du" are reported in the same "small" results, they reports their compressed size instead of their real size? makes sense but I wonder how much "correct" is that in reality, if you want to know the size of your data is reporting a wrong value, you should only care that your disks saves space as much as possible, but this is wrong! Example: let's say you want to copy data to your USB stick, you verify the size of this data and then you are surprised that it doesn't fit on the USB!
Now, see the final (real) space used, shown by "df" is, is much bigger! 339MB in btrfs instead of 271MB by reiser4! 64% used vs 44%! Damn... this is a big difference, a non-sense one since both FS uses the same compression algorithm! (big spank to btrfs! :woman_facepalming:)
More interesting results: btrfs: I deleted all the files, and "df" shows that the 6% of the filesystem is "wasted" (used) with no files, reformated the partition, the 3% is wasted in never-used-before space (16.6 MB exactly). Now, with reiser4: only 132KB used (not even a real 1%), copied all the files + removed (multiple times), 140KB used, LOL!
A last astonishing result: the time required to copy all the files with btrfs is 9.33 seconds. While in reiser4 is 4.98 seconds (double write speed? what?
we are serious?). Also this is interesting, erasing the files and copy them again, in btrfs shows random results, between 4 and 9 seconds in every attempt, but with reiser4 it is extremely precise: between 4.99 and 5.14 seconds in every attempt.
lol, I have no words... why? because this amazing FS is not included by default in the kernel, maybe its time to someone fork the kernel project in a new one :mwahaha:
TKS @Thanatermesis VERY VERY INTERESTING...
2006 lol, we are 13 years ahead on reiser4 development since this video (already existing and developed)
